Just a heads up that on a 2002 LX 470, owner's manual shows the tilt/telescope fuse to be #50 in the fuse panel at the driver's side foot panel (North American model) but it also shows that same fuse as controlling the the SRS system. So pulling the fuse to disable the tilt/telescope will likely also disable the airbags.Sure, it’s #19 on the passenger side panel. See images, hope this helps.
Too lazy to read through the thread, what were the part numbers and what year?I did both today - telescoping and tilt motors. It was a pain in the balls though, wouldn't want to do that again. Took me over half a day. Always some cable that won't unplug or some bolt that is difficult to get to and won't unscrew or screw back in.
I bought my motors from Amayama, shipped from Dubai, since Impex didn't have them in stock. Got skinned by customs though, so next time I will think twice about going the same way and look for alternatives.
Anyway, if anyone has questions about the whole process - I can help.
89231-60022 - Tilt motorToo lazy to read through the thread, what were the part numbers and what year?
This is on my short list and I keep putting it off
Were you able to figure out a way to "Grease" the steering column bushing? I noticed that the original grease hardens over time and I think the restriction of movement is what causes the telescoping motor to burn out.
There is a Toyota grease kit, grease and syringe, just for this service. I'll try to find mine later today and post it for you.Were you able to figure out a way to "Grease" the steering column bushing? I noticed that the original grease hardens over time and I think the restriction of movement is what causes the telescoping motor to burn out.
heli-coil might work. available on amazon (not in us, so no post).Trying to avoid creating a new thread and hope someone can help me out. Has anyone ever tried to clean up the threads on the tilt motor hole for the spindle? Was taking out my old motor today and noticed that threads are destroyed in one section, now I can't get the new motor back in straight, wants to crossthread when it gets about halfway.
Trying to figure out the dimensions on that hole or i'll just have to buy this part and replace it I suppose.
I backed mine out in order to reduce friction to aid the aging telescoping motor, subsequently it's working great but has some radial play.@Jay Tea, I was really excited when I saw your post as I have play in my column and I was wondering if your trick here would help me. I was thinking I could maybe "tighten up" these screws.
But the more I looked into it, it seems like there are springs in there that are supposed to hold the bushing up against the Upper Column Tube? Curious how this fix is working for you? I was thinking about taking this section all apart to figure out what is going on with mine. I also see I need to get some shear bolts?
(Friendly FYI I also posted about this in the main column replacement thread here)
In order for you to further tighten your steering column (remove play) you may have to place something to shim up the existing springs as the bolts are bottomed out, which has me thinking, do you still have the springs in there?
You shouldn't need to drill anything, those shear bolts are what hold the steering lock onto the column (as well as the column tensioning springs/ramps).That is exactly what I was wondering. I have a feeling the springs or bushings might be gone. It looks like someone has been in there before.
From what I can tell, I'm going to need to pull the whole column to be able to drill out these shear bolts?
Oh! Good to know. I thought the two hex bolts and shear bolts held it on.You shouldn't need to drill anything, those shear bolts are what hold the steering lock onto the column (as well as the column tensioning springs/ramps).
The springs are behind two in-hex screws/caps.
I did not need to touch those shear bolts when disassembling my rack.
I don't believe that would be possible, the main bush has a locating nub and the two lower bushes sit in a recess on top of the wedges, there wouldn't be enough clearance to install them without pulling the column from the tube.Assuming my bushings might be worn or gone, do you know if I could install bushings as well without having to take the column out of the tube?
