Tried tackling this job yesterday but ended up a bit stuck.
Tilt/telescope both worked when I got my truck 4 years ago and stopped working at some point afterwards, I just adjusted it once and didn’t touch it later. Would not go in/out when starting the vehicle, but the previous owner had disabled it via TechStream. Only noticed it was broken when I tried adding the rear diff lock bulb to my instrument cluster and couldn’t actually get the cluster out. No loud noise coming from the steering column, the button just wouldn’t do anything.
Yesterday, I pulled all the trim, and before installing the new motors, figured I’d just unplug the old ones and plug the new ones in without fully installing them to make sure the new ones were good.
- When adjusting with the knob, the new tilt motor makes a sad whining noise, moves about 1/10 of a revolution, and then stops
- When adjusting with the knob, the new telescoping motor makes a very quiet click but does not spin at all
I then went and unplugged the new motors, plugged the old ones back in (which are still installed) and they both make the very quiet click when I try adjusting with the knob, but I don’t see anything moving or trying to move.
After that, I pulled the ECU-B fuse (seems like this is for the ECU memory), and observed the same behavior as before even without the fuse inserted. Originally, I wanted to unplug the ECU, but it seems like a major PITA to get to so I held off on that.
At this point, I don’t think it’s likely to be the motors, but I put the FSM and EWD into Claude so I have a plan to test them with my multimeter.
Seems likely that it’s one of the following issues:
- ECU or wiring from ECU is bad
- ECU is not calibrated after I swapped out the motors several times
- Sensors are bad (haven’t seen lots of info on this here)
My next step was going to be to disconnect the battery for 15-30 mins, then try undoing the hex bolts to manually adjust the steering column a bit and swap the new motors in, reconnect the battery, and see if that somehow fixed things. But I’m not sure if I could get the motors extended to the point the truck expects.
One thing I noticed is that my telescoping motor seems to be absolutely maxed out - maybe it’s out of spec? Is it supposed to go this far out?
