Divorced Oil Cooler
Washington
Has anyone separated the oil cooler from the block? Looks like it would be pretty easy to tap threads into the outlets loop those together and then have an external oil cooler. Air even at 90 degrees has to cool better than water at 185 degrees? What disadvantages am I not thinking of? Why would Toyota have put a "cooler" under the exhaust manifold?? Can anyone else think of another engine with an internal block mounted water cooled oil cooler?
My old Porsche 944 had this. Basically the same setup; oil circulated through the cooler and then coolant circulated around it internally.
An external air cooled unit may cool the oil too much with low ambient temps? Also, I think the coolant is used to stabilize the oil temps, as coolant temps are pretty stable, same principle as the trans cooler looping back to the rad after the liquid to air unit.
Cooling the oil too much is easily solved with an oil cooler thermostat
http://www.summitracing.com/parts/ear-501erl/overview/
I was just thinking you could get the extra heat out of the engine coolant system. You could probably cool the oil better when it is really hot.
I think I am going to run separate coolers for both my engine oil and my transmission oil so the only thing the radiator is doing is cooling the engine coolant. Not to mention you are no longer worried about transmission fluid in your coolant or coolant in your oil if you have a problem.
^^^^ this. Many 944 owners had engine failures due to the seals leaking inside the cooler and allowing oil and coolant to mix.
My Cummins 5.9 has the water cooled oil cooler in the same location. You water has long since evaporated by the time your oil is hot enough to flash. Do you not think Toyota/Cummins engineers know what they are doing? Do you have trouble keeping water temps down?
Toyota and Cummins know what they are doing, but they didn't put 4+" of lift, 37" tires, bumpers, etc on their trucks from the factory. I am not worried about the oil flashing. I have zero problems with temperature in my current truck. But this isn't for my current truck. Just thinking that it is probably cheaper/easier/less complicated to use the current setup not sure it is better. Was just wondering if anyone had done it.
Trans lines into the radiator is for faster trans fluid warm up. With Toyota you dont get OD until you trans reaches "operating" temp.
It was my understanding when overheating, water exchange will pull the heat out the quickest.
See now if I had suggested this everyone would think I was nuts and not needed and overkill and blah blah blah.
I purchased this back in 04 SC days for the same reason but our crew chief at the time talked me out of it.
If you would have suggested it, it would have been. Because your plan would have had diverters and trap doors and lights and sirens. :flipoff2:
Who was your crew chief and what were his reasonings? Was your SC being raced competitively? I would think in a race car it would make a lot more sense!
He used our TT as an example. Even running a dry sump set up we could over heat the oil and water temps were normal. No water to oil heat exchanger on the truck just separate huge coolers. Water to oil heat exchanger is the most efficient way to pull heat out of the oil.
On a Toyota without going through the radiator it would take a longer time for the trans to get to operating temps to be able to use OD.
No racing for my SC just trying to get it to run cool in AZ.
I think most external coolers have a thermostatic control that only opens above 130 or so degrees. Like the water cooling system, proper oil temp is above that number. The advantage of the factory cooler is to bring oil up to temperature quickly with the water. The external cooler idea would be nice in a supercharged or Turbo application for extra cooling but I would use a thermostatic control and keep the factory cooler
Inefficient oil to air cooling is what made porsche finally give up on the air cooled (really oil cooled) motors, unfortunately.
