Distributor Clamp
Santa Fe, New Mexico
So I just installed a # 19100-61080 vac advance distributor on my April '75 2F. Do I need to use a new distributor clamp? The o-ring is in the block but the clamp needed to sit a bit higher, so there are a couple of thin washers under it. I simply can't get it to seat lower. I have oil pressure, but for whatever reason, the unit will not go that last millimeter, or so. I verified engagement without the clamp in the event that the clamp was distorted and causing trouble. It goes just shy of the large diameter shoulder, above which the clamp holds.
One issue with a new distributor clamp is that it is flat on the bottom level with the block. However, the new distributor sits just shy of that, meaning that the lower ring of the clamp would be on the edge of where it is supposed to clamp. What do I do?
This may answer your question. I had a similar question about my dizzy not appearing to seat all of the way. Of course the "wizard" set me straight.
When I went to an FJ60 big cap I upgraded the clamp to the later model, it’s seams more secure and I found it easier to determine that the dizzy was properly seated.
I have an '81 Dual Advance distributor in my '81 FJ40. I have a M8 bolt in the distributor but wont tighten. I dont have a clamp on there now . Should there be one?
What does it look like?
@Dizzy - I believe when I installed a new 61180 it didn't seat flush on that notch. The hold down clamp I used worked just fine.
With a Sniper install, I upgraded the dizzy. My FJ60 big cap dizzy doesn't use a separate clamp, but has a location for bolt to secure it to the block. NOTE: Image below, courtesy of Cruiser Corp.
KY -
That’s how my ‘85 2F motor with the big cap dizzy sits.
The bolt is an M8-1.25.
No clamp.
Looks like your dizzy is seated all the way. If the tang on the dizzy misses the slot in the oil pump drive, the distributor base only sits up a couple millimeters from the block, but you won’t get any oil pressure.
Always check it with a feeler gauge or something on install.
Rocky
My bolt head is 12 mm as well, but the bolt diameter is 8mm. The thread pitch is metric 1.25
I just yesterday ran my bolt through a die to clean up the threads. I’m very confident in these numbers.
Rocky
PS. Your ratcheting wrench is a good idea. It’s very tight in there with the oil cooler, distributor and oil filter.
This snap on made dealership SST is a must have
it is availble direct from snap on without the Toyota stamp and sst # too
I swear by it 💯 %
big cap 2F
small cap 60180
new non usa med cap
all 12mm hex lock down bolts are no match
I always win and it loses and locks down !
So, catch-up on the old thread. The clamp was raised by a flat washer to have both of the rings on the clamp holding all of the clamp section on the distributor. I don't recommend deviating beyond Toyota, but, clamping the lower ring on the smaller side of the shoulder will distort the clamp, pull it from the block, and compromise the tension on the bolt (which broke during assembly, so I replaced it).
My part number is 61080, is that the above described, '60180?'
Clearance is around the oil filter and push rod cover, otherwise, they seem universal fit across F, F.5, and 2F?
