Dist. Vacuum Module on 1975 2F
This is the last time I bug y'all.
This FJ I've been resto-modding is nearly done. I've not touched the motor until now. The big ugle offf the wall Rochester 2JET carb that has no ID on it anywhere was tossed aside for a Webber 36/38 or similar, bought from a feller here on Mud.
My question is:
This Dist has a vacuum module with the nipple on the outer edge of the largest portion of the module pointing upward, there is a large rubber cap covering the front of the module where you would traditionally see a vacuum line on any other make vehicle.
Now, when I see this I am reminded of the old ADVANCE/RETARD dist. ford used to use. The rearward nipple on those was to retard and the foreward one was for advance, HOW does this 2F style supposed to work?
1: Constant vacuum to the dist?
2: Vacuum only when throttle is opened?
3: Should I change positions the vacuum hooks up because it's a webber?
I have NO books on the 2F nor the FJ so any assistance is appreciated. THIS part of the guy's build is free of charge as I told him I would tune it up once the new carb was on for nothing, but he's bucking for the parts.
Can anyone help me to understand this vacuum system?
FE
P.S. THe search function pulled up about a ZILLION posts, about building FJ's and the highest on teh list was a chevy motor, I know chevy motors like the back of my hand so that didn't help...
OK, after goinng through 17 pages of the search function utilizing the word VACUUM only I finally found a statment saying that pre 75 FJ's have a vacuum retard ignition.
The windshield is a 74 but the title and tag is a 5 of 75, and the vacuum nipple is where I would call it a retard system.
Not that that's established, thanks everyone, Can I use the Webber 36/38 on a vacuum retard dist?
OR, can I convert the dist without having to change it?
Lastly. I did NOT see any DEGREE marks on the flywheel other than the silly 7* BTC bump. (Hopefully it's 7* BTC and not ATC) Should I make my own degree marks in order to run this Webber carburetor?
FE
Wow, this site is awesome for info but slow as molasses as far as answering posts is concerned...
I'm gonna go back to the search function....
FE
Perhaps if you looked in the Tech Links area, you would have found the information HERE on distributors, as Jim C. details the OEM distributors in this area. Looking in this area for information concerning these vehicles is also suggested in the opening post of the Frequently Asked Questions list, or F A Q.
On your timing concerns:
The dot is seven degrees before top dead center. The line is top dead center, which again, is something that is out here in many threads.
Given the space between the two, one can easily use their best judgment and get their timing very close to a specific degree BTDC, even if it is not marked on their flywheel.
FYI- If I were working on your truck with your distributor, I would not connect anything to the vacuum retard diaphragm, and I would set your timing at the lower edge of the window, at approximately 9 degrees BTDC and see how it runs.
As far as your spite towards this forum and members in your last two threads concerning not getting answers to your questions fast enough for your liking, may I take this opportunity to remind you that this is a volunteer service that you are not paying anything for. The information that people share out here with others is done so on their own time and is not a service that a single one of these members are being compensated for.
:wrench:
Wasn't SPITE dude, and it wasn't directed at anyone in particular, but people here are awfully quick to say the phrase "search function".
I harbor NO spite for anyone. Not even the infamous Calspec of Georgia.
I do think that my questions asked required very little effort to answer. And I searched like a mo-fo going thorugh MANY pages of people asking questions and getting the standard format of "Use the search button" in answer to many of their questions.
But I still do not have any spite for this forum or it's users.
Thanks for the tips on the vacuum retard. I am going to now go through EVERY ASPECT of that HUGE like in the above post and see what I can learn. Manana I will set the timing to 7* then I WILL degree my flywheel so I may fully see the function of this setup and find out where I get full advance and what RPM is comes in at.
I hope ther aren't many people pissed at me for getting pissed at not getting quick answers, but people do that sometimes. It's called being in a hurry adn being short tempered about it, but it's not spite.
FE
OK Poser, I've been THUROUGHLY through EACH link you posted HERE, TECH and FAQ.
There was some good info in there, but not one person ever tried to explain how a Vacuum retard distributor functions, and that was my next question.
and it's 11pm, I KNOW it's NOT in the tech or in the faq section.... I just went thorugh everything...
I wish I wasn't so vacuum retarded myself.....
Anyone know WHAT specifically it does? I mean advancing the timing is where the power curve comes from, how can that curve be acheived by retarding the timing?
If nobody can answer I will likely figure it out or just give up sometime tomorrow afternoon when it's 200* Farenheit in my shop....
Later! and thanks for showing me the FAQ page. there's a ton of good schitt on that page, just nothing helpful tonight.
Vacuum retard distributors are operated by the emissions "computer". At a particular speed, load and engine temperature, the computer turns it "on" to retard the spark as part of the strategy to lower NOx. When conditions change, the computer turns it off.
So in essence there is NO vacuum advance at all on the 74 model, and that you will garner plenty of power at 7* advance at idle and whatever mechanical advance the dist has built into it, and that's it?
Nothing but mechanical advance operates this?
Is it safe to assume I can remove the vacuum to this dist, and still have the car perform on a stellar level or will I need another dist to replace this one?
Do it the easy way. Start the engine. Put on a timing light.
Put a hose on the dissy and suck on it. Watch the timing marks. This will tell you if it advances or retards the timing.
Now you know!
It's not rocket science!
If you want a vacuum advance distributor with all the 'advancements' Toyota made over the years, then purchase a FJ60 distributor, igniter and push rod engine cover (has a 'dent' to accomdate the large cap on the dizzy). Search FJ60 dizzy or distributor and you will find many threads detailing what was involved. You should be able to pick up all the above for $125-$200.
This isn't about that I WANT, it's about HOW it works... In order for me to repair or adjust things correctly I need to know how it WORKS. There aren't any Vintage Toyota books near me and there's nothing on the web about a75 Toy vacuum retard distrubutor...
Anyone know the mechanical advance amount built into these retard distributors?
Andrewfarmer, I can't watch the timing marks other than a bump on the flywheel because there aren't any.... Not visible ones to me yet anyway....
Buy the FSM if you want to know HOW it works. It is covered in detail there.
Besides the emissions vacuum side of it, it is basically a mechanical advance distributor. With or without the retard, it will function pretty much as Toyota intended. There is about 30 degrees of mechanical advance.
There is a line on the flywheel at TDC. You just haven't looked carefully enough. Just watching which way the BB goes would be good enough to tell you if it was advancing or retarding.
You will get more butterflies with sugar than with vinegar.
I didn't put out any vinegar.... not at first anyway... The above post was an emphasis on the words not a stress level. :)
Thanks for the advance info. I will mark the TDC with a yellow crayon, and then check my timing and my full advance.
It's running great now! THis webber 32/36 is right at the verge of being too small, but she's just fine with a little tweaking.
I set the initial timing at abuot 9* btc, plugged all vacuum to the dist. put in new plugs, then started it up and ran her at about 2,500 rpm for about 3 minutes, then read the plugs.
They all came out perfect!
Took a helluva long time to get the answer to the questions I asked, but they DID get answered:)
Sorry for being a prick... I'll make up for it next time I do an FJ-40 and be twice the butthead that I have been to make up the diffrence....
You asked on 8/27 at 6:04 PM. Your last post was on 8/28 at 4:19pm. That's less than 24 hours beginning to end. I don't consider that a "helluva long time."
