You will want to use the cut off wheel to cut the welds then grind it smooth with the grinding wheel or flapper disk.
Be very carful not to hit the ac lines on the drivers side!
OK, I will have to go buy appropriate drill bits, looks like mine are all ate up.
Another NEWB question:
Will my rechargable 20VMAX drill be able to make the holes, or do I need an industrial looking drill that is shown in the instructions?
Yes be careful! Don't ask how I know...![]()
I have all my lights on the factory fog light circuit. They only reason you would need 2 circuits is if you want separate switches.Ben,
Just got my Bumper, very happy! off to powder coating. couple questions, I thought I post them here for future customers' reference.
In your setup, 2x 9" LED light and the 3x3 side LED, are they using the 40amp harness setup? (same relay, fuse and wires and one 20amp rocker controller)? or do you split them using two set of harnesses? (am no electrician).
I calculated that after completion, I will be adding on additional 60 lbs or so. (stock is about 40 lbs, new bumper with light will be around 100 lbs, no winch). Front will sag, but would it sag to the point that i need to adjust Torsion bar, or play with AHC sensors? How have your customers done it?
Thanks for the support,
. If it drops only 3/16 as @benc said, i think its negligible, and just let ACH work a little. I think will be fine. Thank for the explanation and clarifying. Break it down for sure!!!Just got mine mounted, everything is finger tight at this point. Quick questions on final install for @benc or anyone else:
Thanks, I'll post pictures of installed Bumper once I get it finalized.
- Paint assembled or break it down and paint pieces individually?
- Should I use locktite?
- Does anyone know what hex size these bolts are? I don't seem to have any bits that fit properly.
Honestly I have never used a torque wrench on the front bumpers, the rears I do but the torque on the front is less crucial.Ben - just got my kit back from the powder coater. Looking to do the install this weekend.
Do you have torque specs on the various bolts?
