So im really looking into getting disc brakes and p/s. Ive heard minitruck steering is the cheaper way and saginaw is expensive, and thats about it. Is minitruck steering just pulled from a junkyard?
And disc brakes..who sales and a good set of rear discs for a 79?
Yes. 79 - 85 4WD. I try to pick up the works at once, PS pump and front axel. You remove the old box and bracket and install the new bracket in the same place, same holes(brackets are available for as low as $50 on ebay} If your truck is a 79 there should be holes already in the block to mount the pump.
Like Poser said, search and you will get more reading than you will care to do on this, but I did the mini truck PS and I have 33" tires, that is the max I would even try to run with this setup and they are still rough on it. It is an easy to do setup (I gauge this by the fact that I actually did it myself). But if you know someone who welds and does moderate fab work I would go the saginaw route, I would now in hindsite. And may still go that route.
My biggest complaint is it works great "at speed" but on the trails and idle it just doesn't want to turn as easy as it should. I may try a smaller pulley to see if that will help.
Go with saginaw IMO...I kinda wished I had but I think i'll just stick with what I have until it stops being power steering and starts acting like manual steering again
