- Joined
- Jun 15, 2015
- Threads
- 9
- Messages
- 38
Hello to everyone in this Cruiser MIT University...
Ive been gathering information since i acquired a 74 40 to tackle disc conversion.
I recently purchased a complete 84 60 front diff, brake booster, master and prop valve, Knuckle rebuild kit from Cruiser Outfitters, inner seals from Marlin.
Assessment after dismantling the knuckle from the 60 front diff assembly.... need new rotors,purchased Brembo vented disc and brake pads, need new calipers, purchased a used 4runner calipers from Toyota Rancho in Sacramento. In the process of cleaning parts using oven cleaner and WD 40, then wire brushing, still thinking about what to use to paint the knuckles and calipers.
At this point i need more info regarding inner axle shaft, can i use the inner shaft? Or will the outer birf mate with the existing inner shaft sorry if i dont have the terminology correct.
Also what do you guys recommend with plumbing, is it better partial hard line from the master to the diff? Then flex going to the caliper?
Thanks in advance i know we all live pics, i will post some soon.
