Difficult door hinge pins
Denver, CO
I recently removed the doors (and top) on my '78. It took an act of congress to get the hinge pins out. They seem to be really tight going through the middle part of the hinge that's attached to the door. Does anyone have any tricks for making that procedure easier? I already chipped a little paint in the process. I'd like to minimize the damage going forward.
Before you say it, while I like the concept of the quik hinges, I'm not terribly interested in grinding and welding on my rig until it's time to re-paint when I become independently wealthy.
Thanks in advance...
Wait a minute...
Maybe I missed that the factory hinges just bolt into the tub? I thought for sure that they were welded. I might have to go the quik hinge route unless somebody has some sage advice for keeping the factory hinges.
Bolted to the A pillar.
You can lightly hand sand the pin then grease it ... the head of the pin you can shave off to clear the angle
It will get much easier.. I used to give it a good wack and it would pop right up after awhile of removing and putting back
When door hinges don't come out easy...
In all seriousness, are the pins driven in from the top of the hinges? I have found the top hinge doesn't like to come out with a scuff or scrape of the A-pillar drip rail. If you drive that top pin in from the bottom of the hinge, it holds the same and doesn't scrape the paint.
If you try to remove the factory hinges, the top one is a bugger... just be warned it's a tough spot to get to when swapping new hinges in.
Cool. Thx for the insight. I actually didn’t have any issue clearing the windshield with the top ones. I just had a hell of a time getting the pins through the gauntlet. Would be awesome if I could use an air hammer for the operation.
Definitely seems like the quik hinges are the way to go if I’m planning on taking doors on and off more than once. I could see that installing the upper ones will be difficult. But I should only have to do it once.
Slipping a thin cutting board (like the thin poster board thickness ones) between the door and the hammer gives you some protection over good paint.
I don't have the measurement in front of me since this was 20 years ago but...
If you take off the bottom (oh, 1/2" maybe) the pin and leave enough (about 1/4") of the pin to hold the bottom female portion of the hinge, it works perfectly. Holds all 3 parts of the hinge AND clears the A pillar too. It's also invisible modification. You don't have to cut or grind off the metal and paint. A 1/8th drift pin and a hammer gets it out in a flash. About 15 minutes of work and no cost.
For the clearance issue, I agree with the quote, sand and grease.
It is not that hard to fold the windshield a little to get the top door pin out
No reason to scratch any paint ,
A drift punch is all it take
I like to open the door a little and support it with a floor jack and a piece of 2x4 under the door. , sometime you can feel the pin getting loose by playing with the jack up or down
