Differntial Bearing$$$$
Hello all, I'm driving a 97 LX450 with about 150,000 miles on it and I love this car and really don't want to get rid of it. The thing is, my mechanic recently informed me that the front differential bearings are going out and need to be replaced. I notice an occasional shushing sound coming from underneath and am wondering if that is where the noise is coming from. Otherwise, the car drives fine and no other noises. The parts have to come from the dealer and its going to cost about 1400 bucks to replace them. I'm wondering if I should shop around for a better price or is that about right for such work. Do the parts necessarily have to come from a pricey dealer? Thanks in advance.
Wheel bearings maybe - differential bearings, unlikely - unless the diff has been run dry. If the diff has run dry, you'll hear a howling from the front axle. To run it dry you'd have had to ignore weeks of gear oil running down your tires and puddling on the driveway.
The slushing/sloshing sound is much more likely water in the panels. There are slits in the pinch weld that you can unclog with a zip tie. See also sunroof drains.
Like the others have said it's highly unlikely there is something wrong with the diff. I've got one with 260k miles on it pulled apart on my workbench right now in the middle of a part time conversion. Everything was within spec, and I am only going to replace a couple of seals.
I'm in Albuquerque,NM, and I"m aware that the noise I hear is not necessarily the problem. I had the vehicle in for some other work, namely replacing some fluids, and they informed me of the problem. I really don't hear any kind of howling noise or see any leaks. The wheel bearings have been looked at recently and a few seals replaced, so thats probably not the problem. Thanks for all your advice.
as per above, its very unlikely the differential bearings need to be replaced at this point. Wheel bearings take all the load of the vehicle on them and need to be replaced with more mileage than this.
That depends a lot on service use and maintenance.
If the diff has been run dry, then yeah, I could see the bearings there start to howl.
If the wheels have spent time under water, or worse saltwater, the wheel bearings can wear prematurely.
Many of these trucks are getting their axles opened for the first time in 15+ years and 140K+ miles. That seems to be where an unmaintained system starts to break down in more damaging ways.
Remember, the average consumer's take on vehicle maintenance is, "I'll wait until something breaks then get an oil change while I'm there." So long as those axles weren't making loud noises or throwing smoke and sparks - they weren't going to get touched beyond brake jobs and the occasional Oil&Lube shop guy cracking the fill plug open to show them how dirty the fluid they weren't going to change for $75 per diff was - if they could even get the diff plugs to budge.
