- Joined
- Apr 21, 2005
- Threads
- 115
- Messages
- 25,868
Or just move to the desert where you have to work to get things to rust.
But then it is hard on plastic and rubber parts.
my number 1 is ballistol - The World's Most Use-ful & Environmentally Friendly LubricantThin nylon washers and Vaseline are the true trick to assembly. You can torque down without tearing paint, another tip, wisdom I have done it and nothing works better Mr Greenspan. Kinda like sweating metal before paint.. O **** is that why modern paint booths pre heat and get over 100 degrees??
Also expansion foam in all captive and box areas to kill oxygen and moisture.
works even fine one rubber and other surfacesLiving in the Past Or just move to the desert where you have to work to get things to rust.But then it is hard on plastic and rubber parts.![]()
Oh ya
Gotta ask...did you take pics of it behind the wrecker...both going and coming back from the body shop?
Omy!!! You will not be getting much sleep for the next week!
Wish I was closer![]()
Reguarding mounting the body to the frame: bolt the body to the mounts loosly, attach fenders,aprons,front bib, and hood. then shut the hood to align all panels, when happy bolt it tight and check everything for squareness. Then loosten all bolts and align and tighten the body again. It will be perfect. Too many frame off folks get the body back, bolt it down and can't get the front clip square. Simple "'DO IT TWICE" operation. PS, lookin great. John
Hey Shane, think I can get your help shimming the tub mounts and getting it square one weekend>?
I think there is a science to it, and I rather do it right once then 8 times![]()
When you open the garage man door can you smell paint? Or can you open the door with your eyes close and smell it? If so its not cured yet.
True story, I bought a restored FJ40 about 10 years ago from some dumb ass, the thing would not pass DEQ as the sniffer was picking up the fumes from the paint and I could not keep it in the garage as it stunk so bad. Who ever painted it did not mix correctly and proly not cured to this day. It went back to the seller....
