I just saw the price. Maybe I can sell my 80 in order to fund this and just set the lights on the shelf to look at$1,000,000.
I keep seeing these pop up. Does this housing require you to run HID setup? I recently switched to the 9011/9012 HIR setup. Don't guess those bulbs would work in these?
Yep. Everything minus the Depo's. This is not the regular price. It will go back up.
I just saw the price. Maybe I can sell my 80 in order to fund this and just set the lights on the shelf to look at. Wow!
Nick, I'd be down for a set at that price if you can get your minimum 5 buyers. Cheers, Salue
How hard is it to separate the glass lens from the housing to paint the chrome bezel? Heat gun, or oven? I've opened up several headlights before but never some with the glass housing. I painted the housing black on my little Nissan...
can be had for less 600 if you do it yourself. I finished mine for about 540.00. super simple to do just. Everything you need can be sourced from TRS www.retrofitsorce.com, everything is pretty much plug and play once you have your depos retrofitted.
H4/H1 is also the stock setup for HDJ81's, but the stock headlights still suck.
I recently installed a pair of Depo's to replace the stock H4/H1 setup and the difference is night and day. Stock headlights had Osram's, running Phillips +60% in the Depos.
