For a while the decision was easy, since 80s were quite a bit cheaper than 100s. Now I'm seeing 100s that were the same price as 80s were just a year or two ago and nice 80s that are really going down in price.
If I could justify it, I'd have both. For for a daily driver (100) and one for the weekend toy (80). I personally don't want to give up my solid front axle, despite the horsepower increase. For my purposes, more of an expedition fire/forest/desert road hauler, either rig works fine and 100 probably would actually be more comfortable and enjoyable, which is why I'd like both. But there's an added sense of security with the suspension and axles of the 80.
One of the odd things about Toyota's 100 design is the lack of a full floating axle in the 100. Something I really want to have as a security measure. But oddly enough, Toyota significantly increased the rear diff and axle size, so it might stand to reason that rear breakage may be less likely than an 80.
As far as IFS, I don't care what anyone says, solid axles have the upper hand in slow serious off roading...no matter what. I've run both stock and modified IFS systems, SAS trucks and now my FZJ80 and there's no comparision to IFS with solid front axles...except in one area...high speed running over fire roads and the desert. IFS can really soak up the bumps and maintain control far better than the solid axles. Which is why the type of off roading one might do is so important in trying to decided which rig to get. Both will do adequately in all types of off roading, but one definately had an advantage over the other depending on which type it is.
While not nearly as simple as an engine like 22RE, I'd personally rather have to work on and troubleshoot the 1FZ than the 100 series V-8. But the 100 series doesn't have the dreaded headgasket problem, so that's a big plus. All of us that have not yet had the headgasket issue, have this damn worry hanging over our head all the time.
Shotts would tell us that the 100 is far more refined than the 80. He might be right. I've noticed there seems to be a lot less issues with the 100 than the 80. For example, no head gasket issues or transmission issues like with the 80. I'm sure Toyota engineers really went all out when designing the 100, so one could benefit from that expertise. The 80 was the first true luxery off roader and 100 likely benefitted from all the lessons learning in designing and building the 80.
In the end, I kind of figure that my next rig, years from now, to replace my 80, probably will end up being a 100 series. As mentioned before, preferrably the newer model with the 5 speed auto and more horsepower. Years from now when into a price range I can afford. But for now I'm MORE than happy with my 80.
