Death Wobble questions.
Hi guys,
I have a 76 with mini truck power steering. I have the dreaded death wobble. I will start off with I have searched every thread about this and have chased my tail.
Specs.
Skyjacker 4" lift springs
New bushings in frame
4.75" eye to eye shackles
6 degree shims
All new rod ends
rebuilt tight center arm
new dampener
checked wheel bearings
checked steering box
1/4" toe in.
33 ltb super swampers that damn near impossible to balance.
With all of this, I checked the castor with a digital protractor with a straight edge on top of the knuckle studs. This measurement on both sides was only .8 degree positive. One would think I would have more castor with 6 degree shims. Do they make 8 degree shims? My next trick is to install shorter shackles in the front and see if that helps.
Some pick of my setup.
Any advice would be helpful
I have the almost exact set up as yours. I have a 4 inch Skyjacker lift, 33’s and a mini truck power steering. I initially installed the 6 degree shims front and back but I ended up reducing the rear angle shims to 4 degree to improve drive shaft angle and I removed the shims on front spring completely. This seemed to improve the feel of my front end on the highway. Also, if you used aluminum shims, take them out and install steel shims. The aluminum shims will compress and the move around. Also are the pins that locate springs lose in the perches? This could be an issue that leads to death wobble. Tires and wheels could be another thing to look at and maybe a bad wheel or out of balance tire wheel combo. Are your shocks new? Maybe a bad shock up front? Hope something here helps you find your problem. I would vote for taking front shims out first, l removed mine and can drive 65 MPH with no wobble or wandering.
I have steel shims . I would think by taking the shims out I would make the problems worse. I think I would have negative caster then. Wheels and tires could be an issue, but I hope to get it under control without getting new tires and wheels.
My castor was spot on after I removed front shims and looked off when they were installed (keeping knuckles straight up and down visually). I did take a look at my shackles and they are SOR extreme 1 inch extended and measure 4.25 center to center, slightly shorter than yours. I have zero tire wear to indicate a negative castor. On your power steering set up, are you using a rag joint? Just curious.
A pic of your pinion output?
Worn swampers are probably cause.
Agree that longer shackles will make caster worse.
Mine was doing that without shims, fixed with 6 degree which put me at 3 or 4 degrees
1/4” toe in seems excessive for regular tires... not sure on swampers. I’d reduce to 1/8” unless more is needed.
I have a newish rag joint. The steering is tight. I can see the tire move with the slightest touch of the wheel. I would think with the 6 degree shims my castor would be more. Tonight I will try the shorter shackles I have. I think I read that 1/4 toei n was stock.
My wobble would start at place in our subdivision, low speed after hitting small bumps.
Would remind me each time of a shopping cart front wheel vibrating.
It was a great delight upon putting shims to be unable to recreate it.
But as you’ve read, lots of contributors to this issue.
I think 1/8” toe in is stock.
I would try more caster, about 2 degrees. Big tires at less than 1 degree is marginal.
Also, measuring across the top of the knuckle studs is not optimal due variances in length and insertion.
Might try the tire swap. How would you measure castor without taking the steering arm off? I would try more castor, but I already have 6 degrees in. Do they make an 8 degree? I have never seen one.
Without cut/turn, pinion should be level or slightly down in my experience
It sounds like you've covered most of the culprits. I've read that while castor being out of spec can exacerbate death wobble, it shouldn't cause it. I'd do some tire/rim swapping (front to rear) and see if that helps. Also trunion preload should be checked. Finally, don't be scared to go heavier on your wheel bearing preload.
I fought death wobble for awhile with my 35" MTRs after finishing the Rubicon a few years ago. I rebuilt the knuckles, replaced bushings, replaced tie rod ends, etc. I finally just said piss on it and installed an aftermarket (Skyjacker) steering stabilizer. I haven't had a problem with death wobble since. I know some people say steering stabilizers are just band-aids that mask the real problem. And I understand that. But, for the price and not having to worry about death wobble anymore, it was worth it to me. YMMV.
Stock had the pinion flange perpendicular to the ground.
