those look like the ones that i have for my 77 but i’m not sure they’re even the right ones. i haven’t installed them yet
Thanks. Not sure which piece slides and to which direction....can you mark on the picture please?That flat piece covering the bolt head is a clip. It slides off. The bolt head has a tab on it that keeps it from rotating when you put the nut on it. Try something like pb blaster to free up that inner part of the bushing from the bolt.
Ordered new bolts from Japan. Still struggling on getting the middle bolts out (position 2 on toyota drawing)Yes both the bolt and clip are still available oem parts
Thanks a lot! That's exactly what I was missing.The circled piece is a spring clip. It is held on by friction. You pull it outward.
Pic of the clip.
Removed/installed
BTW- I see you used the cushion of positions 1 (left part on picture below) in position 2 instead of what daystar suggest (right part on my picture below)? If so, any particular reason?The circled piece is a spring clip. It is held on by friction. You pull it outward.
Pic of the clip.
Removed/installed
At the time I did it I had a reason. I think it was because the rearward locations are the same setup so it didn’t make since to use different hardware on them. I played around with it awhile until I got something I liked.BTW- I see you used the cushion of positions 1 (left part on picture below) in position 2 instead of what daystar suggest (right part on my picture below)? If so, any particular reason?
View attachment 3295105View attachment 3295106
Thanks
ThanksAt the time I did it I had a reason. I think it was because the rearward locations are the same setup so it didn’t make since to use different hardware on them. I played around with it awhile until I got something I liked.
What did you make that cutt with? Mine did not look nearly as nice.So...a quick update (hope it helps someone):
I finally installed the set after struggling releasing the middle rusted screw.
The installation is pretty straight forward one you make the following preparations:
1. Took 2 of M02850 and 2 of M02421 and created a 31mm diameter and 3mm deep opening (to accommodate the round tooth on the frame holes in back and front)
2. Created 2 sleeves to accommodate the large diameter of the hole on the M02388
See pictures...
The only thing I didn't figure out how to remove are the cushions on position 4 (M02201). I took one off but the was some screw that broke...
With a lathe machine...What did you make that cutt with? Mine did not look nearly as nice.
Thanks. I'll figure it out...maybe I'll break the screws and put the new ones with some rtv....in any case it's under pressure.My rear floor was completely rusted and I welded a new one in. I didn’t have to remove the old ones. I welded a locator (short piece of bolt or round stock) to the body mount pad.
