I have decided that I want to put in a custom dash piece to accept a few more gauges, switches, and buttons. I plan on going with the same lines as the glove box door and the instrument cluster have and will have it cut out of 1/8" either steel and have it painted or aluminum to match my after market gauge cluster. I whipped up a quick sketch as to what it might look like. I'd like some input on what others would put in a new dash group. I wanted to add a trans temp gauge for my 700R4, Voltmeter, and air pressure gauge for when I add on board air (eventually). These will be angled towards the drivers seat using autometers angled holders. I'm sure I've forgot something. To give you some specs on what I have already:
Guage cluster has:
Take a look at it and let me know what you would change, add, move, etc.
Nick
- Flaming River tilt column w/ hazards and blinker on column
- Ignition is to the left of the steering column
- Wipers are to the left of the steering column
- Left turn signal to the left of steering column (obviously
Guage cluster has:
- Tach
- Speedo
- Oil Pressure
- Engine Temp
- Fuel
- High Beam Indicator
Nick
For when I feel like doing some Toyko Drifting!!!
I found this which matches my gauges ....
