Good morning. Well it has been awhile. My ammeter worked for about a year and then stopped. I finally got around to checking it yesterday. Everything checked out, continuity through the circuits where needed and 12.5 volts at rest where needed. I even pulled the cluster twice, the second time to install a brand new Ammeter. Even doubled up the length of the 14 gauge wire loop. Any ideas? Back to oCapice!
Okay, see the picture below.
Take out that "old" piece of wire (marked orange) with the taped connector.
Connect the White/Blue from the harness to the Black Fusible Link wire and the Black wire to the Ammeter.
Connect the White/Blue from the Ammeter to the other side of the Fusible Link.
This is important otherwise the Ammeter will show reverse reading.
Part ll
Your test..... nothing wrong with that and the temperature. You're draining your battery at high speed and yes.... that creates heat.
The wiring in those Cruisers is on the tiny side. As soon as the engine is running and the alternator does his job, your temperature problem will disappear.
Rudi
Yep, ammeter brand new out of the box, it metered 0 ohms through it just like the old one. Alternator fairly new as well. I do have a digital volt meter mounted on my tuffy console (which I cant see while driving) and it is pushing plenty of volts Yes, I'm baffled. I like the look of yours for sure. Too bad NLA. This is a daily driver, if the alternator was bad, It would have manifested itself long ago.I guess you know for sure that your alternator is good? Other than that, a head scratcher.
I replaced my stock ammeter with an off-the-shelf aftermarket voltmeter, but the mud member that made the custom mask for that doesn't make them anymore.
