daily driver birfields
Missoula MT
Hi all I am getting ready to rebuild my front axle. I have a little clicking while accelerating through corners. I have read almost every thread on the subject and don't see much for daily driver birfields. The two options I see are oem birfs and slee has a set of after market birfs. I have kids that seem to use up any money I have so the oem are a little out of my price range. Like I said this is my daily driver and I use it to hunt and fish the back roads of Montana. I do some wheeling but nothing to hard core. Are the slee birfs a good option? Are there others that I should look into? Also is slees after market knuckle rebuild kit as good as oem?
Thanks for any help.
Swapping birfs from one side to the other can work. It moves the areas of wear to a new spot. Plus it's free!
How much grease is currently in your birf housings? Should be 2/3 to 3/4 full. Clicking might even go away with just adding proper amount of grease.
Nitro makes OEM quality replacment Birfs. I ordered a set from Just Differentials earlier this week. Cruiser outfitters has them as well as number of other vendors. They still aren't exactly 'cheap'.
AXTBIRF-FJ80
A swap can work, but you may find that they are too worn for that, I was hoping to swap mine, but there are grooves on both sides of the housing. Once you have the BIRF removed, you can disassemble it and inspect it for wear. It is obvious in the wear location. Be sure you note how it is assembled before you take it apart.
I did my front axle at around 160k miles, the birfs had been clicking while turning before hand. Didn't swap sides and the clicking has been gone for 10k miles, new grease can make a big difference. Theres a good chance your current birfs have a lot of life left in them.
The grease is around were it should be from what I can see from the inspection hole. I might just order the rebuild kit for dan. Take it apart and inspect them. If I have to just order them after its apart.
If I do end up replacing the birfs do I need a longer outside flange or something? My truck is a 94.
I have almost 50k on my Longfields and still looking great. Cleaned and repacked them about 1,000 miles ago. Daily driven 52 miles round trip to work. 2 trips to Moab and Ouray and once through the Rubicon with no issues.
So, I hear it is not recommended to run a crome moly axle/ birfield with a full time front end like an 80 series. I just recently broke the cage out of my 180K stocker. I have another used one there for now & I'm shopping for some new replacements.
After researching it looks like there is...
OEM I have heard $300 to $500
Nitro for $225
Terrain Tamer $160
Does any one know if these have a grease zerks on the end like the gun drilled TGs & what is the benefit of not having to completely disassemble to lube the birfield?
I'm running 37"s & only driving approx 20 miles a day. Also wondering if I should just go with crome moly sets like RCV...
Nitro for $225
Terrain Tamer $160
Now with 261k miles. Mine have been daily driven for almost 3 years now.
What is the production date of your 80? The thicker drive plates and longer stub shafts went in April or May of 94. Post a photo of what you have or measure it. The splinded area of the newer drive plate is well over an inch thick.
Nitro for $225
Terrain Tamer $160
Chromo is springy and tough, but also soft. They won't last as long as stockers. I think the only ones that have zerks is TG and RCV. The benefit is that when you change your oil, you can pop one little cap off and give your birfs a couple squirts of grease greatly extending their life. At least that's when I do it. The alternative is to completely remove the axles to grease them, which sucks. Like I said above the TG's are working great for me, and I DD about the same mileage as you, maybe 10-15K miles a year.
I have a 4/97 lx450
I have to figure if I have 24 or 30 spline or is the 30 spline the upgrade?
Sounds like you have the OG original Longs... that a different story than the TG Longs.
Not a new reply, but a 'slight click' just means to flop them side to side & forget it for another ~150K or more.
Guessing by sig line your birfs have something like 200K on them in the same rotational pattern, correct?
No need to open the wallet, aside from what sounds like about time for a front axle service anyhow. Unless you run into surprises you only need the consumable parts like the seals & gaskets, maybe new nut retainers if yours are beat up.
Your kids need not worry the flow of cash from Dad is in danger of an interruption, haaha!
