daily driver birfields
I have a 4/97 lx450
I have to figure if I have 24 or 30 spline or is the 30 spline the upgrade?
Fact: 80 series spline count at the hub is 30, inside the birfields - 24 and at the diff - 30. My research has indicated that even the upgrade chromo and 300M shafts are of the same spline count. A thicker shaft inside the birf would reduce turning radius. Just don't get stupid and you should be fine.
Sounds like you have the OG original Longs... that a different story than the TG Longs.
That is correct. One of the last few sets before TG took a s*** on them.
You should have the same luck with RCV since they made the Long's.
Get a couple of the Febest Birfields off of Amazon for $50 each and tell us how they work out.
We have seen these last years on daily drivers, as long as you keep the moly in them. Top off the knuckles once or twice a year?!?!
I'm sure chromoly birfs will last at least 100K with proper care. Everyone is always arguing about how long they will last when I'd wager most people replacing them won't keep their trucks more than another 100K anyway just based on age. So if money is no object that is the direction I'd go.
OEM are great and all but the price is up there.
Otherwise based on the OP pretty much any decent replacement Birf should do just fine. (Slee, Cruiser Outfitters, Just Differentials) all offer daily driver type replacements as well as quality rebuild kits with seals/bearings/gaskets. No need to over think this. Pick the supplier of your choice and make a phone call with credit card in hand.
Personally I replaced my originals with Nitro 30s this spring. AXTBIRF-FJ80KIT
