Custom Heater Idea's?
Santa Monica, CA
Website
www.elirubelphotography.com
Not sure if its possible...but ne ideas on how to create some sorta simple heating system for an FJ40...Simple and efficient...somthing that isnt bulky. I was thinking somthing like this- Since I relocated my gastank to under the rear, I would install a small electric heater in some sorta box where the old gas tank used to be under the seat, and hook it up to an aux battery??? just lookin for some creative and funtional ideas.
Thanks
cut some holes in the fire wall and let the heat from that crate engine blow on in
I've got one of those Mojave heaters the P-PO installed...Seems to work well enough and it is compact...
You could get all creative and locate a unit that would fit under the passenger seat, run power to it, coolant lines (if not electric), ducting from it, etc. But, do you want it to look good and be functional or just be functional? By the time you get done you'd probably invest more time, $$, and energy trying to come up with some fabbed up unit with hoses and lines running all over the place than just to go with an aftermarket kit that bolts into the stock location...
GL
GL
Agree.
Friend used a coolant heater from a bus or van or somethin in his heep. The thing weighed a ton, took up half the back, made too much noise and had lines running everywhere.
Stock heater or aftermarket universal would be best.
Forget about an electrical heater. Run the numbers. The amperage draw would be prohibitive. Very inefficient way to heat. Especially when you are throwing away heat from the engine. Install a coolant exchange heater. A "bus" heater. Either find a used one or buy new. You can get one which will fit easily and will provide enough heat to drive yoiu right out of the rig.
Mark...
I went down to my friendly neighborhood Farm implement repair and sales shop. You can score a cab heater from a John Deere for maybe 80 bucks or so. They put out like Traci Lords, and they often have simple controls right on the outside of the steel casing.
I had a 29 model A pu. It had a 2 piece sheetmetal box that went over the exhaust manifold. It had a flaired opening at the front to catch air off the fan. The air passing over the header was heated and ducted into the cab with an open /closed baffle at the floor. Put out more heat than the v-8 with headers in my fj40 ever did. Could have made coffee in a perculator set on top.
my fj55 has a really good stock underseat heater with an electric fan built in. Operates using two coolent hoses running through the fire wall. Works silently and bloody efficiently.
you dont need defrost out there whats wrong with a stock heater j c whitney and every one else sells heaters but there bigger and bulkier plus you have to make dfrost lines and run hoses live on lake erie and stock heaters work well here good luck on whatever you decide
I bought the Mojave heater and after I mounted the optional plenum for the defrosting system I wasn't happy with the look of the unit and how it encroached on the shifter.I returned it and ended up rebuilding and refinishing the O.E.M. unit.The stock unit works fantastic and I think it looks good to.
Well, i bought an old heater off of ebay that came from an old VW bug. Its gas powered and puts out 25,000 btu's of heat. Its about 15 inches long and about 5 inches in diameter. I havent installed it, but was thinking about mounting it on the right side of the engine and running the heat into the passenger side firewall. Just an idea that i thought of, hopefully i can get it installed next year, just dont have the time this year.
