Custom 9.5 front axle build
There are definite advantages to using the 80 balls. Although the birfields aren’t the weak link anymore - even with mini truck sized birfs if they are 30 spline chromo the shafts break before the birfs - the 80 knuckles are stronger. The trunnion bearings are spaced further apart and the brakes are better. The steering options are the challenge, although the high steer options are limited (hellfire knuckles or Slee arms) they aren’t necessary unless running SOA leafs. Linked or SUA you can run a RHD steering arm on the drivers side knuckle and Chevy TREs.
It will never work 🤣
I have been running a Diamond Housing with 80 knuckle balls hellfire, hellfire, RCVs, ARB in a 9.5 3rd for several years.
Our original housing was trussed enough it never bent but we started crushing knuckle balls. Went to the Diamond with 80 balls and this thing has survive hell several times.
If you follow Ultra4 Racing you know.
Why hell yeah, love it!!
Awesome to know!! What gear ratio are you running?
4.88s this has proved to be an extremely reliable combo even in a race application.
best Toyota steering axle money can buy right there.
Have you gotten the housing yet? Worst experience in customer service ever from Diamond. Took multiple emails and contacts and still to wayyy to long.
*sorry to muddy your thread, just wanting to let you know my experience in case it occurred to you or can be avoided.
I have had great service and fast shipping. Brian always gets back to me quickly . Not sure why you are having issues
Maybe it helps if you are a vendor. When I ordered an axle from Brian my 6 week quote turned into 7 months before I got it and it took a lot of phone calls to get it.
As to the thirds' castings, I prefer the 80/100 since it's smooth, thus offering fewer (make that 0) oblique surfaces to snag on. I've been told that it offers improved oiling to the front pinion bearing, but I can't confirm that. As for the housings, I like the SF 80 rear with knuckle balls added. That's on the list of I-should've-done-that-in-this-build. Next time...
Where I wheel, the birfields are still the weak link. We break RCV or trail gear inner cages before anything else. They usually take out the splines on the inner shaft when they pop. I have broken 4 or 5 chromoly birfields and never an inner shaft other than the splines getting stripped off. In my opinion the 80 series balls provide you a stronger steering knuckle, but that is not the problem with breakage that my friends and I experience. Lots of guys with full hydro steering and trunion failures are way down the list.
No, not been received and emails have not returned last 2 weeks. Not my preferred way of doing business, especially when they have your money.
I agree with your assessment. I was told all the 9.5 housings are strong but went with an 80 series because the outside had better lines and expected it would slide off or deflect objects better.
If I read that right you are blowing 80 series RCVs? What kind of rigs are you running and whats the terrain and driving style?
What size tire and what rig/power plant!
Does Diamond make their own 80 series balls, or do they re-use factory ones?
Do you have any good pics of how you mounted your hydro assist setup?? Other than mine being driver's drop it looks like they'll be about the same.
FYI to all, It looks like @TRAIL TAILOR is also manufacturing aftermarket 80 series knuckle balls. I PMd about availability a few weeks back and havent hear back, but he has a thread on them in his Vendor section.
Housing centers are still in R&D.
Jig set up sleeves, outer housing tube clamps and alignment bore rods are complete.
80 and 60 series 4140 CrMo balls are on the shelf
80 Knuckles on the shelf
80 Hi Steer arms for my knuckles on the shelf
4340 CrMo axles for 80 on the shelf
J
