Cummins conversion in process.
Downpipe,wrapped,silicone coated
My guys have a sense of humor..
This is to test the airflow and determine if we need an auxiliary air inlet. If it turns out we do, T@DC will create an airflow valve that can be closed when the need arises.
We are fabbing an inlet to adapt between the box and the snorkel. The duct tape as I mentioned before is to run a test.
Mr.Cim, how do you connect to the snorkel? Is it vented elsewhere ?
Same way as factory. Air cleaner was modified to accept the coupler that came with the snorkel.
Where is the additional entry point for airflow beyond the snorkel?
You can see the plate on top of the air cleaner. The open hole faces the fender wall and can be covered by the plate with four bolts. I don't have any photos at the moment and I won't be back home for a few weeks to take any.
May want to check your oil pressure sensor. Seems like the oil pressure should be higher than that. Mine holds steady at the top middle line when driving.
Get those videos posted:)
The sensor was mapped with a manual gauge and came back well within spec. The Toyota gauge seems consistent even when the original motor was in place.
