Went ahead and replaced my batteries as one of them died. Two group 34s. Should have done 24s, they're a little a taller and more CCAs. I definitely set myself up to fail when I built my battery boxes, as I built them around the batteries I had. One was a 27 and one a 65, so if I wanted to run the same batteries I had to go to these smaller batteries as the 65 and 27 are slightly different widths and lengths. Oops. Maybe next go round I'll redo the trays to fit two 65s.
Thought about doing AGMs but man are they pricey. I've had really good luck with interstates in the past and we ran a ton of them on our fleet of forklifts and those things are HARD on batteries. They were cheaper than any parts store battery and personally I think they're better.
I also did a little more work on my swing out tonight. Cut out some gussets, what a pain, definitely worth it to have Relentless Fab cut them out for me but I didn't want to wait until my next trip to Reno. I'm thinking a big gusset under neath the spindle too perhaps. And then once I cap the tube, put a triangle gusset between the frame and bumper on the back side of that spindle, and a few more gussets on the swing out arm itself it should be pretty rigid. It does shake some if I give the tire a good shove but it seems like it's mostly the upper tubes flexing. Can't see any way around that.
My LED license plate light came in. All the lights on
Amazon I found for license plates either wouldn't work or had mixed reviews. This I THINK will work, with a custom 90* bracket, as long as it's not too bright.
http://www.amazon.com/TH-Marine-LED-51800-DP-Strip-4-Inch/dp/B00AJVL3V0?tag=ihco-20
It has good reviews and can even be mounted underwater so I figured it'd be perfect.
I also picked up a replacement mirror (just the glass) for the driver side mirror. 40s like to fling rocks unfortunately. Hopefully that's an easy fix and while I'm in there I'll do the zip tie trick to take the wobble out of it.
My winch ended up showing up too so I got to thinking about that. Theres plenty of room to mount the winch but I'm wondering how I'm going to run the fairlead and the cable. Thinking I need maybe a 2x8 piece of box tube and cut off about 2" of it and I'll plasma out a hole and weld it in after I clean it up some with a carbide bit (plasma edges weld for s***).
http://www.amazon.com/Superwinch-1585202-LP8500-8500lbs-handheld/dp/B0030E5HS8?tag=ihco-20
The big question is should I offset it some so I can still weld a piece of tube for a hitch receiver into the center of the bumper?
I also need to grab some 3/4" shackle mounts from Relentless Fab as well. I'll plasma holes and then weld them on both sides of the bumper, maybe onto the frame plates too if I can.
I moved that arm up just a touch that way I had about 3" below the arm to work with for all this. That's why I boxed in the top of the spindle sticking up over the bumper.
