Thank you Paul, definitely needed.@MadMace
forum.ih8mud.com
We can certainly look into that. Is the need mainly for the metal ring, or ring and spring and pin?An idea for y'all. The horn brush/ horn seat on early FJ40 steering wheels. It is an easily lost part and difficult to find.
Thanks for working on these components!
Brush and contact plate as a unit and secondly, the rubber spacer (isolator). The contact spring is less easy to get lost but can be troublesome if rusty to provide a good earth. While at it, you might as well make the ring contactand isolator. Ideally offer each part individually or as a whole kit.We can certainly look into that. Is the need mainly for the metal ring, or ring and spring and pin?
Rubber spacer too. Doesn’t seem like much of a part, it’s more than just a rubber washer, but if not a good substitute (the SOR one is not a good substitute) the horn is hard to engage handily or readily engages unintentionally esp. on rough gravel roads.
Do any of you have a spare part I can get in hand and model? I would of course mail them back once I get some measurements . This is the only part I have of the horn assembly at the moment.The spring and pin are needed the most/ a way to mount the spring to the plate. It’s a wear item and easily lost. To my knowledge no one is making them.
Yeah, that would be a logistical hurdle! We will find the parts here in the US no problem.I'm unfortunately all the way down in Africa, so logistics are against us for me to borrow you some samples
Nice! Are you happy with it? If there is already a solution for that part then that is awesome.I also found that a rubber grommet of the correct size and cutting one of the lips off works for the rubber spacer
Do you need to measure the parts yourself? I can pop my steering wheel off and give you some measurements. Or, when my sniper is back and I need some tuning miles, maybe an impromptu cruiser meetup? I’ll bring the 17mm wrench and you bring the calipers?Do any of you have a spare part I can get in hand and model? I would of course mail them back once I get some measurements . This is the only part I have of the horn assembly at the moment.
Yes it has seemed to work well for a year or so nowNice! Are you happy with it? If there is already a solution for that part then that is awesome.![]()
Either works for me!Do you need to measure the parts yourself? I can pop my steering wheel off and give you some measurements. Or, when my sniper is back and I need some tuning miles, maybe an impromptu cruiser meetup? I’ll bring the 17mm wrench and you bring the calipers?
