So I know there are dozens, possible hundreds of threads on this, and I have read them all.
I bought a 96 LX450 that had a OME heavy lift already installed, unknown when, I believe it's 3.5"-4"
I have considerable lean as you can see from the chart below, 1 1/2" to 1 3/4", low on drivers side. My shocks are toast and while inspecting the shocks a swapped rear springs from side-to-side with no improvement, in fact I think it is worse now.
Height to fender lip - Trim - with 315x75 Tires
FD - 39.25"
FP - 41" a 1 3/4" difference
RD - 39.5"
RP - 41" a 1 1/2" difference
Shocks - Like I said, OME, that I am pretty sure have cost me a filling and some kidney damage. I ordered the 2" FOX shocks from Down-south Motorsports today. I would love 2.5", and I would love remote resi, but the budget just isn't there. After I get the spring situation addressed, and all my alignment numbers good, maybe in 3-4 years they will come when these need replacing. But If I am going to drop $2000 on shocks, I may as well drop $3500 and 3-link it. AMIRITE
Castor Correction - I have the MAF drop brackets. The seem to ride fine, but are awfully exposed for damage. I want to replace them with castor correction bushings, or plates. The bushings are a wear item, so I worry they will alter as they wear, as the plates do not wear. Cost is similar. Any opinions on which is better?
Springs - Obviously my springs are crap. They may have 10,000 miles, or 200,000, I don't know. Do I spend $150 on spacers and only install the drivers side, or buy all new springs for $500?. The truck has heavies, and I have ARB on the front with a winch coming this year, The rear has a 4x4 labs with dual swing-outs, tire, cans x2, usually 200lbs of camping gear, and maybe drawers in the future.
Obviously I would rather replace the springs and be good for another 10-15 years and do it right. I am looking at Dobinson 4 " but cant see how to buy them state side but I imagine any 3.5" - 4" properly weighted spring is comparable. I would prefer at level as possible
Thanks again
FD - 39.25"
RD - 39.5"
- Fox Performance Front Shocks for Toyota Landcruiser 80 Series 3 in to 4 in lift
- Fox Performance Rear Shocks for Toyota Landcruiser 80 Series 3 in to 4 in lift
- Given my measurements, on a 35" tire, with a little sag (or a lot) what would you estimate my lift is now? I don't want to go more than 1" higher
- In terms of castor correction are plates or bushings a better option?
- The shocks are bought, so which springs would work well and give me decent on/off road performance given my weight (no actual #, sorry), and keep the current height without lifting to much more (from 41" height on Passenger side)
Thanks again
