Crowded Corner
Fayetteville, North Carolina
Does anyone with a late model 40 have the windshield knob, defrost vents, window crank, and a front roll cage in their rig? I'm considering adding the front part of a cage to mine. Seems like it might get kinda tight with all that crammed together next to the dash.
It's tight. I had '76 on mine and had to open the door to roll the window up or down. Windshield knob is fun to get to. Didn't have the defrost vents. Metal Tech cage.
Yep I’m the same way with my ‘79. Thought I had royally screwed up building the cage until I noticed it’s a common issue.
I have all that except the defrost vents. I have a MetalTech "Jackson" cage. I built mine from their kit, which gives you some leeway on where it goes, how close to the dash and the doors, etc. Windshield knobs are OK, I can get to them with the doors off, which is the only time I'm going to drop the windshield anyway (when the top and doors are off). My biggest gripe is that my window crank knobs hit the A pillars on the cage, so I have to open the doors to roll the windows down or up. If I could have moved the A pillars just a teeny amount closer to the windshield, maybe I could have avoided it - but I have to live with it now.
The other thing the front A pillars do, is make it tight(er) to get your left foot on the clutch. It's not a problem for me, but if I wear big steel-toed work boots then my left foot can be very close to the brake pedal when I use the clutch. It also makes it so that I can't open the kick vents with my foot anymore.
Despite these inconveniences, I'm still happy to have a quality roll cage in mine.
Then there's the headlight switch.
Like this
Just flipped my 76 windshield forward last night. The winshield knobs are tight but NOT a issue. I went the metal tech kit route. So I was able to place the A pillars as close to the door as possible. I’ll attach a pic, I’ve got 5mm between window crank and A pillar.
The PO had cut big Autometer holes in the dash, so I reluctantly moved the light switch to the dash pad.
Crappy old picture. My dash is torn apart right now. :confused:
If someone has photos of the area showing the window crank and vent windows that would help. I'm also hoping to add a cage one day, but having to open the door to lower/raise the window would be a deal breaker, I'm constantly moving my window up and down when traveling. Guy
Change the windshield knobs over to bolts. Problem solved.
Mine has bolts but this does not solve the defrost vent issue. I am considering making a dash tray (delete the stock dash) and pull the corners in more to create more room but this may cause me to not have enough clutch room.
Do you have pics with the defrost vents? I am not seeing how the cage will clear these when I mock it up.
I’ll take a picture after work today. I think there was enough wiggle room with the defrost that they still aim at the windows. But I could be wrong.
If I haven’t posted a picture by this evening send me a PM and I’ll get it over to you.
Curious to know if anybody has made a FJ40 cage that mounts to the A-pillar. I've seen it done on jeeps before, the A-pillar would be shrouded with heavy plate and the roll bar would attach to the plate right below the windshield rather than going all the way to the floor. I've also seen designs that mount the front hoop to a plate on dash, with a matching plate behind the dash that continues to the floor. Similar to a frame tie in for the roll bar feet.
I don't know how much it affect the strength, but it's gotta be better than nothing.
