The perfect "joint" is to have no joint at all. There are expensive cabling suppliers that supply cable for our military POWER-GATE customers that utilize what's called a fusion lug, where the strands of wires are actually fused together and shaped to actually create the lug....you have no joint. This is crucial for high current applications...say 300 amps or more. The cables are very pricey (up to $7 a foot), but of course price is no object when your tax dollars are at work. You'll never get an approriate gasless crimp with hand crimping equipment, and we've also found hydraulic crimping equipment to provide mediocre, relatively high resistance connections. For those of us with access to basic shop equipment, solder your cable connections so the cable bonds with the lug. It's not perfect, but it will be better than crimping by a long shot. You guys would be amazed how hot a cable gets at 300 or 400 amps, even with fusion lugs which provide much better conductivity than conventional crimps by a factor of at least ten.
