Thank you for the replies. So far oil has not been in the coolant or a sludge on the top of the cap....However it does appear some stop leak substance was added and the residue is around the radiator fill neck. Maybe a clue. It is not the white sludge found on top of the valve cover or in the oil fill neck. It has not been using antifreeze and the oil I drained was very clean.
So the compression test revealed the following values are from "back" of engine how it sits in vehicle to front, they are as follows:
140 135 145 140 120 145. Interestingly enough the cylinder with low compression's rocker assembly was the one with white sludge in the picture, Im not sure if that is coincidence or not.
I performed a wet compression test on the cylinder with the low 120 value and there was no change in compression.
This is my thought process now, and please correct me if I am wrong, the low engine compression in the one cylinder could be due to a bad head gasket, or a valve, valve seat, etc. In short a problem with the head or its gasket. Im not sure the next best course of action. Seems I have two problems that may or may not be interconnected. And the white sludge still just may be condensation. One thing I know to be true, It sure is fun and entertaining trying to figure it out!
