The gasket is the same thickness all the way around.
My vent still works and is fully operational after I took it apart and cleaned it up. I used some homegrown foam gasket to create the plate to tub seal. It's interesting that the OEM gasket is two sided, as there isn't a need to have the rubber on the top side of the plate. The only sealing that needs to be done is between the bottom plate and the tub itself. Maybe toyota made the gasket the same size on both directions in order to allow you to flip the gasket around and re-use the topside as the bottom side deteriorated? Otherwise it seems redundant. Off hand I'd say the plate moves up and down about an inch or so, maybe slightly more.
Wow, it's actually asymmetrical. That's quite a revelation. How come the notch is on the outside? Does it serve any purpose? I thought the notch is only on the inside to "grab" onto the vent. Can you please do the same measurement for the inside notch?The thin part goes twds the bottom stock 73.
Thats possible. I do have another set up for a 73. I will try and take a look tomorrow. Im pretty sure that its the same. If i had to guess the one in the pic was never replaced.Your gasket looks a lot like the later 55881-90300 gasket. Are you sure your PO didn't replace it at some point?
The gasket on my sample looks like the one shown at the beginning of this thread. It doesn't appear to have a notch on the outside.
Thanks! Is the build date if these trucks actually in '73 or late '72?
My understanding is that '72 is the last year of functional vents.
I see. 9/72 is likely the last of the functional vent. Thanks so much for the offer, but since my mold is 99% complete, I will finish up based on the existing design, which is a single layer gasket.Both examples are 9/72 (73). Full function vent. If you want a gasket to measure i can send it to you. Lmk
