Coolant Leak
Alexandria, VA
While changing the oil last over the weekend I noticed I have a coolant leak. It looks like it dripping down from just below the water pump.
In this picture w/ the engine running you can see the drop of coolant being sucked towards the fan.
I take it the most likely source is the water pump, but is there something else that I should check out? And how much of a PITA is this going to be?
Does your fan run backwards?? hmmm...The pumps look like they have a weep hole on the bottom side of them, that could be leaking. Or you just need a new gasket for the WP. 8 bolts should have it off. not a hard job, just be sure to clean the mounting surfaces before reinstalling.
Yep, does sound like the water pump and the designated hole for letting the water out when it is failing. Do not feel bad, if you like wrenching a little bit, this is a fairly easy job to undertake.
There was one time that I did not take the job on, however. The vehicle was about 1 week old and the pump went out. That was the only warranty repair needed while the vehicle was still under the warranty period. Gotta love a Toyota's reliability!
Felix,
Like the others said, most likely you have a bad water pump.
If you want to be 100 percent sure, bring it by and I'll throw a radiator pressure tester on there. Odds are thought it's the internal seal behind the bearing in the water pump.
Fix it, use a OEM toyota gasket even if you use an aftermarket pump.
-Stumbaugh
Alright, new pump and gasket it is. Thanks for the help, everyone.
