Control arms rubbing!
The problem with the plates is you have to move the new hole below the mounting flange of the current bushing. While the plates are all different this means there is a minimum amount of caster you have to add in order to use the plate method, and from my measurements even that minimum will cause my arms to hit the drag link.
not entirely true. I designed my plates to relocate both the front and rear holes which allow me to avoid any contact with the tie rod. Not a lot on here to read as people just install them and go about their day.
My current caster is -.5°, I read your plates are somewhere around 5° change, is that correct?
How much clearance needs to be retained between the drag link and the arm so there is no interference, 1/2"?
What about the Marlin crawler high steer kit? Doesn't it move the drag link to the front? That seems like a viable solution.... It would totally eliminate the chance for it to rub...
Is this safe to drive? It still drives fine and I'm not hearing any rubbing. I will get it fixed but I need the cruiser for a small trip now!! Thanks
Good idea I will look into it
My truck is a daily driver and I don't care who makes those caster correction bushings, they are al POS. Under constant use they may last two years. When I lifted my truck in 2010, I had to replace them in 2012. I went back to the OEM control arm bushings and the Man-A Fre control arm drop brackets and problem solved. As of today the truck runs fine and I don't have any problems off road with the bracket hitting anything.
Sadly my sliders will wok with control arm drop brackets, but I do love my sliders so eventually gonna get land tank plates.
You dont have enough lift for most caster plates making you an excellent candidate for the washer mod. Not as much correction as plates but should be fine with 850/860. But if you plan to go with more lift later on forget the washer mod it wont be enough caster.
