Pretty sure most of the Plate Kits out there will produce nearly identical results. Plates will not affect your ride, but they will usually give you better steering thru corrected caster.
One note on this is not all caster plates are created equal. MetalTech's for example were designed around the OME J lift (3" or around there), which as we know is not a 4" inch lift.I believe the problem with the plates is you are adding too much + caster that the arms hit the drag link if you are under 4" of lift... At least that is what my research over the past week or two has led me to believe.
I don't like the offset bushing solution due to decreased flex and the fact that they are poly bushings, which just don't last.
Seems to me the best solution aside from the plates is the trunion bearings that correct caster (unfortunately the bearings are smaller so the lifespan of the bearing will probably go down), or welding more material on the mount itself and re-drilling the hole where you have added as much + caster as possible without interfering with the drag link. The welding solution is equal with the plates in my opinion, with the advantage that you don't have to add as much + caster as the plates do, so you won't run into the drag link interference issue.
seems like the best, but unfortunately most costly option is to do a cut & turn.
I started with Slee bushings and a 2.5" med OME lift, went to J's. EDIT: swapped someone with stock radius arms and stock bushings that had a small lift, replace with stock and ordered some MT plates.
live'n'learn
Should they last longer than two years??
