Control Arm Drop Bracket
S. Ontario
Has anyone here modified their stock control arm drop brackets for castor correction?
Uglibus has a dropped bracket on his 80. I'm sure he'll chime in if he has time. He's pretty busy these days. I will say that he once told me that it sucks and he's always getting them caught on the rocks. Well that might not be an issue anymore as he's on 40" Swampers now.
I think it would be nice to replace the original mount with one that has a bolt hole one inch lower and an inch forward to recenter the axle. This could cure the problem that some people have with their front bumpstops hitting the spring. It shouldn't be too hard to do as long as you can weld or know someone who does. It won't stick out as bad as the MAF bolt on brackets.
The problem with recentering the wheel is that when the suspension compresses it will put the edge of the tire into the front of the fender.
I was thinking the same thing, more or less. Pulling the rear of the control arms down to correct the castor is one way but there would be issues about getting hung up on obstacles.
I've read that when putting in OME castor correction bushings, one has to (or should) use a come along and pull the front axle towards the front of the truck. Why not just slide the rear bushing mount forward and, perhaps, down just a little bit, say forward an inch and down 1/2 an inch. This sounds way simpler than have to press out old bushings, press in new ones and get them all lined up just right.
I do have access to a 12 ton press so that is not the issue. The issue is simplicity.
What say you all?
so it's simpler to figure out exactly where you will fab a new mount, grind off the old mount, weld and fab new mounting brackets?
You still have to unbolt the control arms, you still have to "relocate" the axle to put the bolts back in (w/ straps or whatever) so it's not simplifying, it's adding a lot more work.
caster plates or bushings are simple.
I don't mean to take off the old mount, simply build a new mount that slides into the existing mount opening with two holes oriented form side to side (horizontal). The bolt for the control arm bushing is located ahead ~ 1" in a hole nearest the front of the truck and the new slide in peice is held in place with a bolt through the old holes in the existing mount. An angled extension at the back of the slide in piece would keep it from rotating and getting "hung up". I guess a diagram would help.
the problem with the springs hitting the bump stop is because the caster solution they chose moved the axle back. If the axle is rotated in place there is no contact here.
Rotating the axle in place has been worked out for lifts all the way up to 4", after that you need arms. I see no benefit at all to drop brackets.
Landtank, if you look at the physics involved, there is a huge advantage to drop brackets over especially castor plates.
Castor plates fix castor, thats it, drop brackets get the arms back closer to horizontal, so when moving in an arc they dont have to go forward to go up, bit like a shackle swap on a 40 series.
Even new arms dont fix all issues, they are just expensive castor correction, but dont fix the mounting point angle issues.
More horizontal arms stop the chassis dynamics especially thumping back through the floor, and feeling like the truck has 80 psi in the tyres on sharp bumps.
On anything over 3" we used to swap the arms around, and mount them over the diff to cure this problem, long before we had new arms, or castor plates etc etc.
Some guys weld brackets right below the existing ones, dropping the bolt hole about an inch.
it doesn't matter whether the arms are mounted on top or below the axle, the arc traveled is the same.
I thought that the springs hitting the bumpstop happens because the lift on the spring causes the control arms to be further down on their arch causing it to be pulled backward slightly.
See the highly detailed drawing to help explain myself better:
The black control arm in the picture above would be the stock height and the red would be at lifted height. As you can see the axle moves more toward the firewall the more you lift it (distance between the two blue lines.) The frame side of the spring mount stayed the same while the bottom mount at the axle moved back causing the spring to be sitting at an angle instead of straight up and down which is why it hits the bumpstops, correct?
This is the reason why I would like to move the control arm bracket at the frame forward and slightly down to recenter the axle to its proper location and get slightly better caster. I think it is a good idea. I just don't know if I would replace what is already there, or make plates that straddle over the current mount.
ecameron87, the springs are not straight and are actually in an arc.
The problem comes from tilting the axle verses rotating it. When you tilt the axle the spring perch now points behind the top one and a "S" bend is formed in the spring which can cause it to contact the inner bumpstop. When you rotate the axle trhis doesn't happen.
The worst offender of this problem is the other guy's plates, mine work just fine. And if you use bushings as a caster solution press them in with my template, it rotates the axle as well.
Sorry for the shameless plug.
That does make sense and I can see how bad castor can cause the problem. The crude diagram I made above is probably an exaggeration of how it really is, but I still think that it could play some part in it.
Luckily I have gotten away from the Slee plates on front J springs without any problems so far.
Incorrect.
The closer to "9 oclock" the arms are the less movement back and forth in the arc movement, as the arm moves up and down, the closer to 7 o clock the arms are, the further the diff has to go forward to get to 9 oclock, and back to get to 6 o clock.
Get it?
Its all to do with the position of the front and rear of arm mounting points.
Incorrect.
Get it?
completely wrong! It has to do with the axle's position to the rear mount, period!
If all things are equal, whether the arms are on top or underneath makes absolutely no difference in the force applied or the arc traveled.
