Control Arm Drop Bracket
completely wrong! It has to do with the axle's position to the rear mount, period!
If all things are equal, whether the arms are on top or underneath makes absolutely no difference in the force applied or the arc traveled.
see post 10, its the arm position and length that control the back and forth movement as it goes up or down, the closer to horizontal, the less back and forth movement in the arc travelled, its the diff location that determines the direction of forces involved over the mount.
The only two things that will change the arc that the axle travels is the distance the axle is from the pivot point and the position of the rear pivot point to the stock location. How that arm is mounted whether on top or underneath has absolutely no bearing on how the axle travels.
So, unless during a flip you are doing something to change one or both of those constants you have not done anything to alter the axles movement.
You have just repeated what I was saying, the length of the arm governs the distance from pivot, of course, no need to re explain what we know, the location of the arm will determine how far the diff moves back and forth, as it moves up [or down] always.
This diagram shows how if the central point is at horizontal and diff moves up and down, it moves less than half the distance than it would if the arm sits angled down,a nd doesnt come up to horizontal,
it's the distance of the axle to the pivot point and it's relationship in elevation to it that governs how it moves.
The distance is controlled by the arms and the elevation is controlled by the springs. So unless the arm flip alters the distance, it makes no changes to how the suspension travels.
OK, one more time, I will type it slower for you this time......
its not about 'travel" its about the arc the arm moves in, and how much less it is when the arm is horizontal vs steeply angled. If the arm is horizontal, the diff actually moves back as it goes up, if the arm is down in the 8 o clock position it has to push the diff forward to go up, because the arm length doesnt change.
The force up into the arm when it has to try and move the diff forward to go up, while the bump is trying to push it back, means as long as the arm is horizontal or as close to as can be, between mounting points, it will move back and forth less than a larger angle. we have seen some vehicles punch the mount out of the chassis, when lifted to high and not "re aligned" not to mention the "kick off" and handling issues this creates.
this is going to be my last post on this hi jack so you can have the last word and everyone can assume I disagree.
It has nothing to do with how level the arm is. It has to do with the relationship of the axle and the rear bushing mount on a horizontal plane. Relocating the arm so the arm is more level has zero bearing on how the axle moves through the arc. Until you change the relationship with the axle itself and the rear bushing all forces will remain the same.
"out of hi jack"
"out of hi jack"
You just contradicted yourself.......
"It has to do with the relationship of the axle and the rear bushing mount on a horizontal plane."
Is close to what i have been saying, but it should say
It has to do with the relationship of the axle "mounting"and the rear bushing mount on a horizontal plane.
Which we know already........
"out of hi jack"
the problem with the springs hitting the bump stop is because the caster solution they chose moved the axle back. If the axle is rotated in place there is no contact here.
Rotating the axle in place has been worked out for lifts all the way up to 4", after that you need arms. I see no benefit at all to drop brackets.
The problem with the springs hitting the bump stop is the bumpstop is lower than it was before, and the axle is in a different possition when it hits them - or at least that's part of the problem.
Landtank is 100% correct. It does not mater if the arms are on top, on botttom, or any other place. Doesn't matter if the arms are straight, or bent, L-shaped or like fluffy clouds cut out of 3/16" plate. The path the axle goes, and the amount it goes forward and backward is a simple arc, with the center at the radius arm mount, and the Radius is the distance to the axle center.
Because of the possitioning of the bushings, they'll likely move forward and aft less, and therefore bind less.
This has been gone over before:
https://forum.ih8mud.com/showthread.php?t=81731
and here is probably the best dwgs on mud about it (yes, mine, but if someone else posts something better, I'll say mine aren't the best)
https://forum.ih8mud.com/showthread.php?t=144461
'Tank & 'Eagle you need to read on angled leading arms in your handy dandy suspension design 101 book.:D Angled down (from frame mount point to axle mount point) leading arms, increase ride harshness, reduce traction, increase bind, etc. Making them level by moving the mount points on ether or both ends improves suspension function.
From a simple drawing it easy to “see” the relatively static numbers, caster, etc. It’s hard to “see” the dynamic changes and these are a bigger part of suspension design. Download a suspension design program, input the link numbers, then move the mount points. Watch the numbers like squat, instant center, roll center, etc and you will see that mount point location, arm angle, etc make a huge difference.
I think I understand what he's trying to get at. I think the one thing that needs to be clarified is that the change he's speaking of is NOT relative to the axle/rear bushing, actually he's speaking of the relationship of the axle to the front of the vehicle. In other words, the centering of the axle from front to rear in the chassis.
The axle will be as far forward as it's going to get in a stock height vehicle at rest. When the suspension compresses the axle will actually move rearward slightly, likewise with extension. All because the arc the axle/arms travel in and the fact the axle is centered in its arc relative to the vehicle and suspension movement.
Because of the arc the axle/arm travels in, the axle will move rearward at rest relative to the front of the vehicle when lifted, correct?? If thats the case, when the suspension compresses the axle will move forward under compression because the axle is no longer centered from front to rear in its range of motion in relation to the vehicle. I could possibly see some extra shock induced to the suspension because of this. Just imagine going 60mph down the road and hitting a big pothole. When you hit the pothole the suspension compresses but the axle wants to move forward, fighting against the vehicles forward momentum.
Keeping the arms horizontal, whether it be by drop brackets or by flipping the control arms, will return the axle to it's centered position in it's range of motion.
Whether this is an issue or not is another question.
Tools -
I can see the bind being reduced by flipping arms -
but, the rest of it - on a radius arm (we're talking front, not the rear 5-link afterall), really is only about the one mounting point and the position of the axle, if the radius arm is mounted on top or bottom isn't really going to effect the motion, or the forces it transfers back to the body/frame. They're all going to go back through the same mount point. There will be a x and a y component of the force (and z, but that get's complicated) when the tire hits something, and that x and y will be transfered to that mount.
4 link or 5 link, ya', you'll get a bunch more going on with different mounting points on the axle.
nope - pick a mount, pick an axle distance from the frame / mount (spring height), then draw an arm to the bottom of the axle. Where does the axle go as it cycles up and down? Now, flip that arm on top of the axle, same springs, same axle to mount location, where does that axle go as it cycles up and down?
Having effective arm (don't know if that's the right term, but I'll say it's the arm that would be there if you draw a line from axle center to radius arm mount) that is more level, certainly gives most if not all the bennifits that tools is talking about. Moving the radius arm mount on the frame (drop brackets) is the only way to make that effective arm more level. Changing the shape or mounting of the raius arm will not.
Heck, you can even cut off the front of the arm, add a y-link and you'll still get the same behavior straight line and ride wise - you'll get some different results in articulation though, depending on how you mount the bushings (angle the top ones, they bind less in articulation that way).
Yep, didn't quite think of it like that. Basically it's just a mirror image of itself.
But I do think the drop brackets have some benefits, no?
The reason I entered this discussion is because I'm planning lifting my rig. The drop brackets seemed like an easy solution for me, but couldn't understand why people dislike them, other than the ground clearance issues of course.
It seems that both methods of caster correction have their advantages and disadvantages. It's up to the owner to decide which is better suited for their rig.
The drop brackets have some definate benefits. They are the only way of getting the 'effective arm' more level. They have less fore aft movement than other options, therefore less binding (less is a vague term of course). I went through a whole list of which caster options have what bennifits on that other thread
I run them. I like them. I think the street handling is great. I wheel plenty hard with no issues. I didn't have to take the arms to get bushings pressed. I didn't have to worry about getting them in at the right angle. I didn't even get it aligned after the lift though I should have - but after close to 25,000 miles on new tires, no uneven wear - probably just lucky
Now you guys are getting what I was explaining, the arm is best in horizontal position, and flipping it on the diff gives you that on bigger lifts.
Castor plates fix castor, that is it, new arms fix castor, that is it, rear of front arm drop brackets fix geometry, and castor, flipping arms fixes geometry and castor, plates and arms dont fix the arc the diff has to travel in with a big lift, which means the wheel has to go forward to go up still.
