Complete list of all rubber mounts / bushings that squeek or rattle and wear over time
US
My suspension rattles from multiple places and I decided to replace any rubber bushings that I could find. It's 26 years old and the majority of the bushings that I can see are cracked and dried out. It took forever to find them all then get all of the part numbers so I figured I would share them here
ENGINE / DRIVETRAIN
OEM PART NUMBER
YEAR
-Engine Mounts (2)12361-50120
12361-50121
1998-1999
2000-2007
-Transmission Mount12371-500811998-2004
-Diff mount bushings (front)Lower 41654-60010
Upper 41653-60020
1998-2007
1998-2007
FRONT SUSPENSION / STEERING
- Front Lower Control Arm bushings​
Front 48654-60010
Rear 48655-60010
1998-2007
1998-2007
- Front Upper Control Arm bushings48632-60010 1998-2007
- Steering rack bushings (rack-to-frame mounts)45866-600201998-2007
- Front sway bar frame bushings (D-bushings)48815-601111998-2007
- Front sway bar end link bushings90948-02180 + 90948-01003
1998-2007
- Front shock upper bushings90540-17006 + 90540-17006
1998-2007
- Front shock lower bushings90903-890161998-2007
- Bump stops48304-601001998-2007
REAR SUSPENSION
- Rear sway bar frame bushings48815-601501998-2005
- Rear sway bar end link bushings48817-300101998-2005
- Rear shock lower bushings90385-190101998-2000
- Rear shock upper bushings90948-010641998-2000
- Rear bump stops48306-60140 1998-2000
BODY / FRAME
- Body mount bushings (cab mounts, 18 total, front to back)52201-60050 (x2) + 52202-60030 (x2)
52203-60060 (x2)
52205-60020 (x2) + 52206-60020 (x2)
52207-60080 (x2) + 52208-60040 (x2)
52216-60030 (x2)
52209-60071 (x2)
- Radiator support bushingsUpper 16584-66010 Lower 16584-610201998-2007
MISC
- Hood bump stops (2)53497-12050 + 53498-12050
- Exhaust dampers17581-700801998-2007
- Exhaust isolators at mufflers/resonators17565-74280 + 17565-13030 + 17565-74280 1998-2007
- Fuel tank mounting cushions776523-3010
77654-60050
77651-60130
77652-60060
77651-35060
77651-60120
1998-2007
These are all for non-AHC^
If I missed anything, please let me know.
woah that table did not format right, i'll fix it
edit: fixed
if anyone knows of aftermarket poly alternatives i can add those too
has anyone ever replaced body mounts? i think mine are squeaking, and depending on how difficult it is - its almost annoying enough to convince me to do it
I'm pretty sure that's a fairly easy replacement, the problem is the cost. They're $60-80 a piece and there's 18 of them. I'm with you though, squeeking drives me insane. If it's any consultation though it's unlikely that it's your body mounts squeeking, more likely that it's a suspension component. I need to look for some aftermarket alternatives
My squeeking comes from multiple spots both the front and the back, and its whenever I hit a bump. I've found two of the sources but I am having a hard time narrowing down the others. So I'm gonna start with those then go from there
another sqeake source: threaded small dia rod/bolt that holds the rear side window hinge. tends to vibrate loose over the years w. anoying squeak.
I don't have hinges on mine, honestly didn't know that was a thing. I'll find the part number and add it to the list
This part is making a lot of noise from the hose rubbing against the bracket. It's not adjustable though, and I don't know what it is. It's literally not on parts diagrams, so I'm honestly tempted to remove it. It's attached between my brake line heat isolator and the frame
here is a thread that discusses the rear vent window(s) "hinge".
I just looked and mine does have these, lol I had no idea
48815-60150 this is the part number that I have for the rear sway bar to frame bushings from partsouq
48815-60140 is the part number from Toyota
I think the japanese spec UZJ has different diameter sway bars than the US spec, but I'm not sure. Would hate to order from japan and get the wrong size
