Interesting, it doesn't look like there's a hinge on the front end, just rubber molding with two bolts in it. It just pivots on the flexibility of the rubber. You remove the grab handle and seat belt upper, then pull of the entire plastic trim surrounding the window and there's two bolts you access through the C-pillar.
Martin, if it's the motor on your window that's not working, there was someone selling a motor here. Their window broke and a new window comes with the motor. IIRC they wanted a pretty penny at the time.
Thanks for the info. I found it helpful to detach the lower seat belt attachments to allow me to pull out the lower trim as well. There is a section of the lower trim that seems to interconnect with the upper trim section that prevents upper trim removal.
The solution was to tighten a nut (lock-tite added) to pull the vent window back to the pillar.
Chuck
SO after a lunch time trip to Mark Miller Toyota this afternoon - I have to buy the entire motor set up to fix the small plastic latch - price tag $287 for the motor. I'll be looking on here first. Cory - where was that post at?
While we're on the subject of the rear wing windows. Mine, when open to max, have always rattled...even on the street. Everyone's the same? And now the DS doesn't close as tight as I think it should so its an entry point for all that Nevada dust.
I can see why Toyota eliminated the operating wing windows on the 200. Based on my '99 they couldn't figure out how to make them function properly.
There are gull wing replacements available, but they're expensive. I haven't seen anyone convert the existing glass to open all the way.Has anyone been able to convert their vent window to allow for loading gear through there? ie, detach the buckle and covert the hinge to something that allows full articulation of the window
I was pretty close to going for these but it just didn't add any functionality and bailed on the idea. I put the orange box fab panels on the inside.There are gull wing replacements available, but they're expensive. I haven't seen anyone convert the existing glass to open all the way.
