More for Bob
Musta been before my time here, don’t recall seeing thatBTW, Pat ( @landcruisnman ) shows up with this shirt pictured (second down in the above post) and doesn’t remember who he got it through. Does it ring a bell with anyone??
Iron Pig Preservation Society (!)![]()
One fantastic viewpoint on Thursday's run was right at 10,925 feet. From that point you can see about 90% of the Sangre de Cristo range, from the north end above Salida, CO to very close to the south end above Santa Fe, NM. The distance as the crow flies from Salida to Santa Fe is right at 200 miles, so we saw about 180 miles of the range from that spot.What’s the elevation out there? Thinking 6000-7000’, how’s the sniper set ups doing?
Quite a few Sniper setups at the Party.how’s the sniper set ups doing?
@Pigeaten
@landcruisnman
@DTC72
@abqcruiser
Pigeaten (Don) had issues the first couple of days with a fuel leak and throttle cable. Got those ironed out and he was able to climb on up to +10,000ft without a problem.
Landcrusnman had an interesting issue with his hydraulic clutch system when, how can I describe this(?), an extension of hard line for the clutch master cylinder/slave cylinder plumbing between the lower passenger side firewall and soft line going to the slave cylinder, cracked and started leaking fluid. We ended up removing the short extension and hooking the soft line from the slave directly to the fitting of the upper section of hard line on the firewall. I wouldn’t understand if I read this either, so hopefully there’s some pics out there that will help with the visual.
My Sniper performed flawlessly at elevation and on the drive from Las Vegas to NM. I had to change both pre and post filters before the trip though.how’s the sniper set ups doing?
