Cold Weather & Larger PS Cooler
Bend, Oregon
I recently sent my steering box to get resealed, and since everything is all pulled apart, I was planning on installing an aftermarket power steering cooler in place of the paperclip. I ordered one up from amazon, (http://www.amazon.com/Derale-13260-D.../dp/B004XONQYG) and should be here soon.
However, got to thinking after reading some other posts, I don't want to cool the fluid too much! My cruiser sees conditions anywhere from 100+ in the utah desert to -20 on ski trips, so now I am reconsidering my decision to put in an additional cooler. I don't want a squealing pump all winter, especailly since I think the location of the stock cooler on the front crossmember would get covered with slush and whatnot as the mag chloride melts the snow. This would probably "super cool" the PS fluid.
Has anyone run a larger cooler on an 80 in very cold weather, and if so, how did it work? Do I mess with the stock configuration that seems to be pretty well balanced across a number of conditions? The current cooler is in good shape and has very little surface rust.
I wouldn't mess with it. :cheers:
No issues, but how much is it actually working?
I'm not sure exactly by what you mean how much is it actually working? This is my daily driver rig through all four seasons where I live. In fact, I just drove over 800 miles all back country (on and off road), up to Yellowstone and back this past week and no whining, leaks, or anything unusual, so not sure what else to report back on. It works for me...
Yep, that's what I ended up doing :) Sent it back to amazon and stuck with stock configuration. Mostly because I ran out of time to mount the bracket. The paperclip is also in good shape so there was no urgency.
Downside is I have about 10 feet of extra low pressure PS line that I don't need :doh:
I was deliberating this exact subject the past couple days and decided to buy an infrared thermometer and see exactly what my fluid temps are at different locations and/ or wait til there is an actual problem. Our mods don't always make it better. Toyota designed our vehicles to satisfy a wide range of service all over the globe.
