Clutch-ing Offroad
player said:
Well, I'm gonna see the cruisr today. Hope I get to drive it around the drive way... I think the gas tanks empty tho. Since the gas is like, 7 years old, is there something I should dump in the tank to make it run better? I'm gonna crank it over a few times to get the oil circulating... Oh, and the rad. leaks a little. How can I temp. fix that? I'll have dial up, I think.
ok. gas, i'd dump the lot and put fresh stuff in
radiator leak, try some ground pepper in there
player said:
So, actually... I could have a front wheel drive cruiser w/o the shift gate?
So the FJ43 is longer than a 40? Thats odd, I think I've seen the pics on the first page of SOR's OnLineCatalog. Where were those sold?
And if it does bind, all I need is one wheel off the ground? What is this "reversing hard"? It sounds... violent... :D
reversing hard is violentish... just enough to get your wheels to spin. in gravel shouldn't take much
the 43 is indeed longer than the 40. they were sold in malaysia, japan, and africa TO MY KNOWLEGE.
alkaline747trio said:
Well, I would if I had the opportunity, but the only thing straight drive I can get my hands on is a Civic Hatchback, and that isn't all too often. I want to read up to pass the time and be a little better at it when the UREs open back up and I get behind the wheel of my bud's Heep again (only thing stick I've ever driven off-road).
I'm guessing you assumed that I had a 40 or 55 since I posted in here, but I saw this discussion and figured I'd ask.
Reckon I'll just have to wait till spring to learn some more...
don't be so quick to get your panties in a twist :) my comment was meant in jest.
really it's one of those hands on things to learn
Ok, going to airport now!
I don't have :princess: panties :flipoff2:
Yea, I know it's all hands on, but a guide helps. Didn't mean to sound defensive, just trying to explain. But, oh well...maybe I can get the old Mil. Heep running and practice clutching, but that would take away cruiser money; so on second thought, maybe I'll just say screw manual and stick with my pansy auto.
could stick a manual behind the 3fe :D
Is there supposed to be a skid plate under the t-case and stuff? I'm gonna have to drop that to get to the shift gate. I dosen't look so "easy" to get to... Its kinda way up there!
So I drop the skid plate, and then i can reach up into that jumble?
can i ask what is the prefered method of clutch-ing in situations where 4lo 1st is too fast for the terrain your trying to negotiate (eg, under instruction)?
i usually let my 40 idle throw some rocky creekbeds and almost run down the ppl in front..
If you have to clutch often, more gear reduction is the way to go...
Aftermkt T-Case, Lower ratio R&P, T-case doubler...
instead of dropping the shift gate for 2LO why not just dis-engage the front hubs? correct me if I am wrong.
p.s. If I want front wheel drive only I can just put my OD in neutral :p
Well, one reason is, I don't have unlocking hubs. :(
and why not just drive it in 2H...............like the rest of us:flamingo:
my wife picked it up, after years of trying in other cars and trucks and we did'nt use 2L:princess: :flipoff2:
why not drive in 2h? how about a high traction section of track, auto locker in the front...
or between hard obsticals?
or reversing a trailer up a steep hill on pavement?
or for annoying people following you in the underground carpark?
or for driving up wheel travel ramps
why not unlock the hubs? well i don't want to get out and do it between obstacles on the trail... every time... also if stuff gets slippery or hard, you can just throw it back in 4wd. also if you do it for long periods of time, you can cook the grease in the hub, or ruin the spindle.
there's no reason not to do it, apart from the 20 minutes worth of effort. and if you've got it and never use it, it doesn't hurt any... oh and i thought it was a silly mod too, but last time my gearbox was out, i did it to experiment, and i use it all the time now.
i'm pretty sure we're still talking about him still getting the hang of driving a standard tranny.
i'm pretty sure he mentioned he has drive plates, not hubs.
i'm guessing he what's the 2L to drive around in a lot while he gets the jist of driving a manual, since he can't just put it in 4L to do so.
Yeah, just so I don't stall too much. I don't have WallyWorld parking lot at my disposal (No registration for the past 7 years), so I figure in 2L, I have more time to react instead of zipping across the lot and mowing bushes down.
I usually stop and let them get ahead of me a bit. Usually this stopping does not happen on an obstacle, so it's not a problem. It's kindof a pain, lower gearing would probably be better, but then again I'm kinda new to this too.
