Is there a way to adjust your clutch ? Have 76 FJ40 and clutch is too low with no giveback more than 1&1/2 inches
Welcome to the forum and congrats on your new 40. I’ll first suggest using the search function. You’ll find plenty of info and pics.
The clutch is hydraulic consisting of a master and slave cylinder. Make sure the reservoir on the master is up to the mark on fluid. The adjustment is down at the slave cylinder. There’s a rod between the slave and the fork that disengages the clutch. The rod is threaded and adjusted there. When you see it, it’ll make sense and so will pics you find with the search function up at the top of this page. Good luck!
It’s always better to know what the inside looks like BEFORE you start messing with what’s outside.
good life lesson also.
forum.ih8mud.com
I looked and all the popped up were old Toyota tucks .. not fj’s esp a 76there are YouTube videos....
Haven’t found any specific to my question etc. any links you could provide for that? And fixing parking brake? I jus get restored projects that aren’t specific when I look on YouTubethere are YouTube videos....
They're not very heavy duty. It's only there to help hold the fork off the throwout bearing. Read through this thread. There are some pics of what it should look like collapsed; the coiled section looks to be about 2" long or so. Is the spring bracket in place, looks something like this?
