Cleaning valve cover.
Twin Ports of Superior, WI and Duluth, MN
I am in the middle of the HG job and I was wondering if I can take the valve cover to the machine shop and have it hot tanked along with the head? I am replacing the gasket, the PCV valve and grommet and the spark plug hole gaskets anyways, so I am not worried about them. What I am worried about is getting the hidden ports full of gunk. The cover looks like crap and I would like it to look nice and shiny the way the heads I have seen coming back from the machine shops do.
If that is a bad idea, what is a good way to clean it?
Don't see a reason not to. I wet blasted mine, but you have to be VERY careful to clean the head as you can't access the interior passages without removing the baffle. I'd avoid dry bead blasting. Or, take it to a shop and have it walnut blasted.
I am not cleaning the head myself. I am counting on the machine shop to do that when I haul it over there for a valve job. I am hoping the valve cover and the intake end up looking like new, stock.
Right. We're talking about the same. Here's my thread on the subject:
Intake cleaning w/Pics
Yes, hot tank your aluminum.
Yeah, a buddy if mine made a sailboat out of aluminum foil to sail a mouse across the hot tank ocean at the engine shop he worked at. The sailboat was scuttled in short order.
Depends what cleaning solution the shop uses in their block washer; the shop I took my valve cover to used some type of non-caustic detergent, came out clean as a whistle, no damage.
As I planned on powdercoating my valve cover I needed to remove all traces of oil as the oil apparently tends to be absorbed by the aluminum. This is why the shop ran the valve cover through their block washer twice, if not three times. I then washed it again after letting it sit out in the sun a day or two, which they tell me can help the oil come to the surface of the aluminum casting (or by putting it in an oven). IME some of the industrial strength cleaning solutions (like Purple Power and water) work better than solvents to degrease large metal parts like this (assuming you don't have access to a vapor hone cleaning machine, see midfat's post above). FWIW.
Avoid the Mercury (Hg) Dip Tank
Oven cleaner.
Nothing works as well on vintage steel parts that've oil bathed daily, removing grease, grime, gunk and paint to, pretty much, paint ready.
That said, there's a damn good reason Betty Crocker wore elbow length gloves.
I've still spots on my forearms that the pigment changed, bright white even with an August tan.
If I take an aluminum part to a machine shop and ask to have it hot tanked and it came out all jacked up, they'd be buying me a new part. For how many parts are aluminum these days, I'd be really surprised to find a machine shop that uses chemicals that may harm certain metals.
