Cleaning Engine Parts
Get ready for pump failure. The impeller on the pump will get cleaner inside and will not turn the fins for the pump. You have to disassemble the pump and whip out the inside of the fins and wipe off the impeller each time or the pump will quit working. Know of three that this has to be done to
mines still going strong 4 years later... guess i got lucky
Quote:
"mines still going strong 4 years later... guess i got lucky"
Could it be the type of cleaner you are/were using?
In all cases, the people were using the grease remover sold by harbor freight. Rather oily in my opinion. It got between the pump impeller and the plastic pump fin. The impeller would just spin and the fin would not.
Ky Fried Washer
Built my own parts washer from a scrapped Ky Fried Chicken, chicken cleaner.
Seriously! It's a Stainless steel wash tub, it would hold 20 gallons but I only put 10 gallons of kerosene in it.
I bought a parts washer pump and brush from Northern Tool and a wire closet shelf from Home Depot. The shelf was hung inside the tank and the pump was placed about 2" off the bottom. I sealed the bottom drain with spare plumbing parts then welded on some castors so I could move it where needed.
Now the best part is it has a large air pump on it. This pump is a low pressure high volume type pump. It was used to pump air into the tank which was filled with chicken pieces. The air came through a pipe full of holes and agitated the pieces to clean them. I can suspend a greasy part in the tank, turn on the pump and air and put the cover on. The next morning the part is mostly clean and will just need a slight scrubbing.
s***ty - I bought some of that too.:crybaby:
As already posted ... Oven Cleaner. NOT the new "low odor" stuff but the original. Let it soak in for a good while and you're set.
