- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,508
Its a Necessary handy Tool........
I have one on my ‘78. Had a very tough time adjusting rod clearance but my mechanic said it is a two person job. That said I have awesome brakes now and would buy his booster again-works fantastic!!
Damn.My poor man’s gauge...View attachment 1674462
That's ingenious. I just dropped $25 on this today even though by my caliper measurements I "think" I'm good. However after hours of failed attempts to get it right I figure $25 is cheap insurance. I suspect yours works just as well in the right hands. Dowel/nail need to be just as long as the overall stacked blocks though, right? Or maybe they are and it's just misleading perspective.I found one online through a auction house type thing , from a dealership in Oregon that had closed its doors
My part # is 09737-00013-01 , Its made in the USA but no maker marks or stamps ? , i dont have the chrome / stainless Rods
like @Racer65 's Japan one does , but looks to be the same general tool , just a Simple USA spec. version
Nevertheless it's a very high quality factory SST
Matt - could you provide the tool dimensions? There are many of these types of gauges available pre-owned but not the exact Toyota SST.
Anyone care to explain how the tool works to ensure proper shaft length?
Is the point to have the end of the shaft just kissing the master cylinder?
if i missed one u still need let me know
I Posted The FSM photo's on page 2 of this thread , It does explain and have diagrams very well on procedures / use steps
After installing the Racer65 booster today, I got to thinking about the original design. The gasket between the master cylinder and the booster might help keep rain out? The 40 and 45 hood has those vents which make the engine bay kinda vulnerable. Also, there is a dimple on the OEM booster at the bottom which could let liquid out, but then I don't know why mine drank so much DOT 3 from the master cylinder? Maybe the master cylinder had it rubber seal with the corresponding grooves pointed up?Right, it's probably the booster push rod adjustment. I'd go without the gasket. Given the clearance spec is 0.1 - 0.5 mm, that gasket can throw you off spec. Besides, the gasket serves no purpose. If the MC leaks in the distant future, it's better for brake fluid to drip out than to be trapped by the gasket and then sucked into the booster.
I honestly didn’t realize there was supposed to be a gasket between the booster and master. Just recently installed both back in my resto. When I pulled the old booster and master out there definitely wasn’t any signs of a gasket, which could have been part of the issue. I guess I need to pull it back out and make a run to the stealership.I installed @Racer65 's 4wheel Drum Brakes on A NON USA 1/79 FJ43 , I was replacing a bad booster leaking fluid from a bad master leaking fluid , His Booster is a Quality part , With factory Fit & Finish , I also purchased and installed His foil decal
Not for bling factor so much ............well not really
, i stamped the original OEM part# in the new foil decal on it now it reflects a correct by the book replacement
also oreded the paper / fiber OEM toyota gasket that goes between the master & the new city Racer booster
Or this... Which is the consensus?Right, it's probably the booster push rod adjustment. I'd go without the gasket. Given the clearance spec is 0.1 - 0.5 mm, that gasket can throw you off spec. Besides, the gasket serves no purpose. If the MC leaks in the distant future, it's better for brake fluid to drip out than to be trapped by the gasket and then sucked into the booster.
