cigarette lighter
Moorpark, CA
The cig lighter in my 81 FJ40 works fine (no I don't smoke). However when I plug in my GPS or cell phone I don't get a connection. Any ideas to get around this minor problem?
Wally
Mine does this sometimes. Rotate the plug about 20 degrees and plug it in
again. Does it work now? If not, keep plugging it in at different orientations.
I found one that works. If you look at the iinside where the outside of the
lighter plug contacts, you might find some corrosion where the plug
is not making contact.
You can put a pencil in a drill with the eraser end out and polish the + contact.
I had a similar problem with my first Escort Radar Detector in a BMW. The Euros used a "cigar" lighter which was slightly larger in diameter than 'merican cigarette lighters. They finally came out with a little plastic piece to tighten it the plug in the larger socket.
If the lighter works, a little cleaning ought to make anything else work.
Oh, and D/C the battery before you clean the socket;) .
Ed
Polish the contacts first, try that. Otherwise change it out for a new outlet that's made for 12v accessories. And never look back.
nial
Is it possible that a PO reversed the polarity on the cig lighter? This would make the lighter still operable (just a big ass resistor that gets hot) but may cause a GPS to not turn on.
I agree with rgentry. The ground side of most of the "accessory plugs" is just a thin strip of metal - where on al cigarette lighter, it goes all the way around it.
Just make sure the ground side of the accessory plug makes good contact.
The pencil eraser idea is a good one too.
Rocky
ditch it and get yourself a nice inverter, then you can watch movies while camping, make toast, lots of things
