Build Chicago builds a 40
Thanks brotha!
This is the reason I havent been on the 60's board.
Dont wanna let ANY time get away from workin on this thing. Im rigless for one, and there has been many-o-projects that have died SITTING for too long.
Sniff sniff :crybaby:
no love for the heavy folks...
:D
:D
I <3 my 60.
However, this 40 is going to be epic. Keep up the excellent work Keith!
I <3 my 60.
Thanks Brotha!
Appreciate the props. Helps keep the motivation up.
I miss you guyz over there.
I fear that ive crossed over I wont be accepted any longer. Although the axles and t case will be 60 series BEEF!:D
Not an ass man?
Lets NOT get carried away now!
I quite FOND of a nice hind side. However, the 60's are just a bit TOO MUCH ass for me.:p
Bob has a nice ass...
Wait till the pics start coming...
hardcore = XXX
Thanks brotha!
well i can understand the project sitting to long is hard to get moving again. my poor 60 is a victim of this:frown: as the 40 is the daily driver.
:D
MUCHO love for the heavies!
The ASS was just too big.:D
i like a nice big ass...
maybe if the 60 was a little smaller but a big ass = much love:grinpimp:
Rear floor pan is in and finished!
That is the last of the MAJOR body work. Now its just fillin in the holes, chopping the other fender, stripping the rest of the paint and little bondo and clean up then PAINT.
Pics of the floor pan. 12 ga steel used. I also had added some 3/16 plate under for bracing, but I didnt get any pics of that...
So last night my wife went out for a girls night with her friends, I was left all alone with Jezebel. Chopped the rockers up to the body mounts, found a rust hole that needed to be patched where the rear meets the front of the cab behind the PS seat. After that I went at her with a wire wheel and stripped ALL the paint off the outside of the tub.
There are still a few areas the need addressing...
In the floor pan in the cab, there are some holes that appear there were once some of those rubber bushings in. Anyone know where to GET those rubber bushings? If I cant find em, Ill patch em...
There on the front where the antenna goes...looks as if the PO had cut the hole with a BLOW TORCH to run an antenna...That Ill have to patch as well.
Next is to flip the tub over and clean the under side, then Bondo, then paint!:bounce::bounce2:
