I've got a '77 fj40 with a '72 SBC mated to a stock '77 4 speed Toyota tranny. This V8 conversion was done by the previos owner in 1982 using a fabbed adapter plate that offsets the trans from the Chevy bellhousing by .580 thick. When i rebuilt the motor in 2001 i went with a Centerforce Chevota clutch from Downey Offroad.This Cruiser has not been my daily driver up until 3 months ago and now im having issues with the clutch .
Problem: A few weeks ago, i started having trouble shifting into reverse. The clutch felt like it wasnt disingaged enough and the gears were grinding. I adjusted the clutch slave pin enough to allow the stick to shift without grinding, but then i would get a terrible low rpm shudder/vibration that im assuming is the throwout bearing not disengaged and riding on the pressure plate. I can even hear a difference in sound when i am in neutral engine running, and release the clutch pedal from the floor, you can hear something turning/ like the throw out bearing not releasing. I'm prety sure the clutch disc is not worn out because i dont have enough miles on it and also my clutch grabs enough to lay down rubber
I'm wondering if the previos owner used the wrong offset ( .580) with his adapter plate and since ive got to pull the clutch maybe i should buy the Advance adapters conversion bellhousing. Does anyone know what the correct offset shoud be for this conversion?
