Chev vs Toy Rads
I had my old toyota rad from my 73 40 recored but that was when I was going to go with a 4.3 v6 conversion. The beast is growing and a 350 is now the planned motor and would it be better to go chev rad (4or 5 core) or is the toy one ok?(4 core i believe)
Will be DD and weekend warrior. 4spd toy tran/transfer. 36's. plan to use a electric fan with either rad.
I wish the rads that I've had in my Land Cruiser were better made. Both of mine have had leak issues with the top tank. I heard it's a common problem with older model Toyota rads...if there was a better bolt up equivalent I would go for it.
I ran a recored 4 row toy rad, ran good around town and crawling, but I had to keep my speed down to 60. The faster I went the hotter it would get. A larger radiator would have cured this. Its just tricky getting it to fit if you have the headlight buckets behind the front panel.
Just use a shrouded puller style electric fan....cause pushers just blow ;)...and you should be fine with your OEM rad.
Ranger ...that sounds like a classic thermstat stuck open (or no thermostat) heating up problem.
I'm running a 4 core stocker with an electric puller fan. Around town and crawling its fine, but on the highway it starts warming up. Acts just like Rangers, and on real hot days I'm limited to about 50-55mph. Cool days are perfect.
I run a 2-core aluminum aftermarket radiator and clutch fan and cannot get it to overheat no matter the circumstances. I did put a lot of care into setting it up right with a Stewart water pump, large oil cooler, and shroud but even without all that I'm convinced it would run cool.
alot of people including myself run stock radiator, it works, and i can only remember overheating once and tha was a hot day 100+ and crawling. other than that works great
No it was not a stuck or open thermostat. It worked as advertised. THe toy radiator is too small for a V-8 in hot climates. You can get away with it in cooler areas, like Alaska, but not it Cali.
The toy radiator does not have enough surface area for heat transfer. Believe me I tried every trick in the book with the same results, the only thing that will fix the high temps on the highway is a larger surfaced area radiator. Water wetter, high volume pump, electric fan, 7 blade cadillac fan with heavy duty fan clutch, shroud, help a little but the problem was still there. You name it I tried it.
when i got my cruiser the radiator leaked bad, so i replaced it 2 years ago with the 4 core that CCOT sells. and with my 350 sitting in traffic on a hot summer day it gets about half way between the first and second mark on the gauge, never any hotter. what ever you do make sure you have a shroud if possible so you draw as much air through the radiator as possible. good luck!!
Hmmm...this is a rather odd one Ranger. Most of the remedies above are more geared toward heating up in the city/traffic where you not getting the air flow that you would at 60 mph. And yes I agree with you, there comes a time in every cooling systems life where capacity is an issue, but I am still thinking something else was not quite right. Was your small block warmed up into the 400+hp range ? What was the gearing/what revs are you turning at 65mph ? What was the dist timing curve ? Also, I see you ran a recore, I have seen some bad recore jobs that severly limit/block the flow thru the tubes. It sounds like you tried everything and opted for increased capacity....a friend of mine runs what has been affectionately been named the "aquarium" ....it is quite the conversation piece.
