Check Engine Light
Atlanta
OK my light came on 2 weeks ago. I had it checked at 2 different places one said 02 and the other said MAF. I cleaned the MAF and installed new plugs, air filter and filled up with premium gas. The light went out after 70 miles. Used up the tank of gas and filled up with Reg. Light came back on. Used that tank of gas and filled up with premium light went out in 3 miles. What gives? I used Reg. for 225K. Any thoughts. Is the premium masking another problem?
What was the specific code?
I never found out. I took it to Auto Zone first and he told me it was o2. So I decided to get a 2nd opinion and took it to the shop I trust. I told them it was pinging a little and seemed lean. He said the o2 normally causes it to be rich. The code he got lead him to believe it was MAF but he suggested I clean it.
The code comes back from the computer and that tells exactly what the problem was, thats why I asked.
It's guess work without the specific code number and what you are saying (I think) is that two different people had two different guesses what the code meant.
OK heading to Vatozone after work.
Thanks,
my check light came on- took it to dealer- said it was a bad ground on the computer. (o2 sensors ok, tb ok, etc...) I just did plugs, TB, use premium gas and it comes on again. I disconnect the ground on the battery, cycle the key a few times and re-connect. Light stays off.
I put in a tank of Reg and after 180 miles the light came back. Had it checked and it is the PO420 code.
I clicked the search function above. selected the advanced tab. Highlighted the 80s section and put the code you got in the keyword section. Came back with a lot of threads on this. This post by Whipp sums it up though
P0420 is Catalyst System Efficiency Below Threshold.
I've had both error messages. Look at your O2 sensors first, as they are used to determine whether the cats are working correctly. I'm pretty sure that the FSM also says to check the O2 sensors first. When I had P0420 I tested and replaced both O2 sensors and haven't had the error come back in over a year. I think the CDAN price was in the neighborhood of $170 for both sensors.
- Craig
If its the cat, a lot of people have gone aftermarket and its no where the cost of the stock setup. Most likely an O2 sensor.
Thanks, I am in Atlanta do you think CDAN is the way to go with shipping cost?
I know thats right! I payed $23.00 for upper radiator hose. I have sent cdan a message.
Thanks,
I live in the ATL and I use CDan. I have relationships with parts managers in this city and Dan can still beat them. If you need a hand with anything (replacing the 02s, or consult on what to do if you end up replacing the cat) let me know. I replaced with a non-OEM cat and can tell you where, who, how much, etc. I got my stock cats torn out, replaced, out the door for less than $250.
That sounds great... I will be in touch... Thanks a ton in advance.
