- Joined
- Aug 15, 2009
- Threads
- 20
- Messages
- 55
I had the check engine light come on and the code was "EGR valve insufficient flow". Does that mean I have a clogged catalytic converter or clogged muffler??? Mine is a 96 LX450.
I think I understand what to do, but are there any instructions that are a little more clear or straight forward?
I hate to rain on the parade, but we need to do a full search and remind ourselves that the VSV is far from being the only resolution to "EGR Valve Insuffient Flow". There are at least four items that will throw that code with varying probabilities of each being the culprit. Make sure you check that port that runs from the EGR valve along the top of the intake. That is a well document offender. Vacuum modulator will throw that code too. As will the temp sensor and sometimes the EGR valve itself is defunct. Old vacuum lines can cause problems too even though the VSV or Vacuum Modulator work correctly.
