Cheap way to keep cool
I did this to keep under hood temps down on my supercharged 4runner. Thought maybe it may be useful for you 80 guys when on the trails in the summer heat. The nice thing is you can easily put it back to stock for winter or selling the rig. Just put some spacers between the hood and the hinge.
Heck my hood does that on its own! Lol Is that hood scoop functional?
No. I have thought of making it functional and attempted to do so, but when I tried to remove the insert to cut it up and make it functional it acted like it was going to break, so I left it alone.
It gets hot here in the summer and I wheel on low sped trails mostly so hood luvers are on my list to do but the hood adjustment you posted could help until then.
Ya it took me 5 minutes, longer bolts, and like 1 or 1.5" spacers. Just make sure your hood will still pop open when you pull the lever, may have to adjust it but I didn't have too.
Were you overheating before this mod? These trucks are designed to operate at a very wide range of temperatures, and at a wide range of speeds. You shouldn't be overheating no matter how slow you are going, and if you are, this mod is just a band-aid (assuming it actually does anything) to a much bigger issue.
Every time Im in Moab I hear 80 owners complaining their truck is running warm and the AC is shut down in the 95 degree desert heat. The Japanese engineers range of design did not include 37" tires, a supercharger, huge bumpers and winches, roof top tents, spare parts, and moving up steep rocks all day in the desert. While they don't really overheat, they run warm. So people may put venting in their hood of some sort to assist in slow speed cooling. This does the same thing but you are not cutting your hood up. Hood venting has been around since the dinosaurs roamed the earth. This is not a new idea, but in my lurking the 80 section I have never seen this done. Just a idea passed on to me that I am passing on if you want to try it.
This works great if you have a supercharger. I cannot tow my popup over the local pass in the summertime without doing this mod. or I will see 220. With this mod I have never seen more than 205.
